Car is back together. Time for some photo spamming.
Took both heads off to get them ported and milled .030. Dropped them off to get CNCd. Milling bumps up the compression to around 11.5:1 with new GM MLS head gaskets.
Took the exhaust off to get the headers ceramic coated and the tips polished.
Fly cut piston heads. That way the giant cam that's in the block won't cause the valves to hit the pistons due to the head milling.
While I waited for the heads to get ported/milled and the headers coated, I decided to get the JHP gauge pods from Australia.
Gauges installed. Had to cut a section out under the dash to clear the harness, but otherwise it was an easy install.
Also decided to port the LS2 intake myself with a Dremel shaping bit followed by a lot of sanding. What good are ported heads when you have an LS2 intake? Spent a couple days on it and think I did a good job. Opened the runner width up from 0.95" to 1.05" at around 2" deep. Smoothed out all of the disjointed plastic edges where the intake layers were welded together.
Ported head intake.
Ported head exhaust.
Driver side head and header back on. Showing the new BTR dual valve springs.
Head and header on the passenger side. The rockers and pushrods went on next. Don't have any photos of that. Went from 7.400" to 7.375" pushrods since the heads are now milled.
