Managed to destroy a dual valve spring
AdamK47
3,628
Car started running like crap shortly before arriving home last night. Thought it might have been a bad spark plug or wire. Never saw a CEL, so I then thought it might have been something mechanical like a broken valve spring. Popped the valve cover today to confirm and sure enough...
phucheneh
7,306
Quality metallurgy right there.
Or just terrible spring design. Is it just me or are all the coils touching? That's a stock camshaft/rockers?
edit: wait...I thought the valve was just open...no, the one beside it is. What's going on there? Bent valve?
AdamK47
3,628
I'm taking the head off after work today to see if there is any damage to the valve or piston. I could just replace the spring and do a compression test. I'd still be worried even if the compression test passes.
Jimzz
4,399
190
Who made those springs?
But some early Z06 Corvettes had problems with broken valve springs and most did not bend the valve and that was with a single beehive spring.
I'd just replace the spring myself and test.
skyking
22,819
5,982
I would not. TDC the piston, remove keeper and broken spring. Rotate valve to check for bend. Reinstall new stuff and compression check. I seriously doubt any damage that would not include a bent stem.
AdamK47
3,628
Did a lot of wrenching after work today.
Love taps.
Valve doesn't completely close.
bruceb
8,874
111
So it looks like a slightly bent valve and minor damage to the piston. You will need to decarbon the piston top and see just how bad the actual material is hurt. Worst case, new piston. Best case, clean it up and see what happens after.
phucheneh
7,306
I think his piston is fine. Looks like it just scraped the carbon off the valve relief. Tiny bit of emory cloth or something to knock down any sharp spots and it should be good to go.
Piston vs valve results in piston victory every time.
I'd try and be as close to 100% sure of what happened as you can, though. Work out the order of things and know why they happened...valve probably bent because it hit the piston. Valve probably hit the piston because the spring broke...why'd the spring break? Rockers and pushrods okay? Valve guide and seat okay?
Are broken valve springs something that is known to happen on those engines?
AdamK47
3,628
The valve springs I purchased are PRC dual .675". From what I gather is that they had a bad batch of them last year and I happen to have them.
It's uncommon for dual valve springs to break like this on NA LSx engines.
The piston is OK. I can grind down the pushed up bits of metal from the valve taps.
Gillbot
28,830
17
If he has stock pistons, there are no valve reliefs........
Gillbot
28,830
17
He may as well fly-cut the rest now and go bigger valves, more cubes, ported everything, forged, boosted and ... what else can he "repair" while he's in there...... ;)
phucheneh
7,306
LOL. I totally thought that was a stock relief. I could sweat I saw one on the piston next to it in that black mass.
That's a fairly impressive dent, then.
CPricecrispi
30
Amazed it didn't go through the piston, so it's a bad case scenario but not the worst one.
I've would've been a dumbass and given it one rev to 4500 RPMs and shot the valve into the oil pickup.
olds
50,127
781
Sounds like me. Blew an intake manifold gasket on my 455.
Had the intake off and ended up pulling heads, going to a bigger cam, new springs, roller tip rockers...
It never ends.
SparkyJJO
13,357
7
It never ends.
Having to fix something is always a good excuse to upgrade while you're at it :p
Downside is the bank account can get a little empty :hmm:
