Kaido
- Feb 14, 2004
- 51,629
- 7,270
- 136
Ever since owning a home (3.5 years ago), I've managed to fix quite a few things around the house by googling/youtube. Definitely takes some time to learn certain things, buy the right tools, etc, but the idea of saving $200 to replace a toilet's pump/flush for maybe 1 hour of learning, and 1 hour of labor definitely was worth it. Now I know how to fix all of my toilets if the internal parts fail. That's just one example.
Also replaced my garbage disposal which was easy because I already had the locking frame in place (same brand disposal replacement) so didn't need to reseal anything. The hard part was cutting the pipes to the correct lengths to get everything to fit properly. Also learned how to clean out sink drain pipes for clogs or slow draining.
But there definitely are other things that I either can't do myself, or am not willing to do myself and will spend the money to get fixed.
What frustrates me is how poorly things are designed. I worked for a custom-home builder every summer in college & it was amazing to see (1) how poor designs are still used as standards, simply because they work, technically, and (2) how even really expensive, multi-million-dollar homes have garbage underpinnings. Even for really simply things, like where you could spend an extra $10 to get a flexible waxless seal for mounting your toilet on, but instead wax rings are still used, get messed up because toilets require a bit of work to mount perfectly, and either have to be replaced, or just shoved in & have future leaks ignored because hey, it's done for today!
My buddy moved into a custom-built house by a carpenter, and it was such a genius design. Among other features, the previous owner built in hidden access panels for all of the electrical, plumbing, etc. You could work on anything, anytime, instantly, without having to tear our drywall or putty or have to repaint. Absolutely glorious!
