He's a good bit more than 200 pounds. He also has multiple personality disorder so maybe each one of them only eats 1000 cal/day.Some former pro running back (I want to say Herschel Walker) claims that he lives off 1000 calories per day, while maintaining his fitness level and weight (like 200lbs with very low body fat)
Making the (assuredly incorrect) assumption that the 275 pounds lost was all fat:
275 lb x 3500 cal / 1 lb / 382 days = 2520 calories per day.
Assuming part of it was muscle and other tissue it would seem he would have had a steady supply of around 2000 calories per day anyway. Throw in some vitamins and minerals and you certainly wouldn't die. I bet you would feel like crap the entire time, though.
1kg of fat is 9,000 calories. 1kg is 2.2 lbs.
You burn 2,000 calories/day. So figure it out.
He should have lost 186.76 lbs.
I doubt it would ever work out to be such a direct relationship like this. For one thing, efficiency in converting ATP from fat stores is very different from creating ATP from glycogen derived through normal "ingestion-based" metabolism. In training the body to take stores from fat, you've already subjected yourself to a substantial amount of biochemical trauma. You literally have to go through a minor starving process before this starts to happen.
And I don't know if this is true, but I wonder if muscle tissue would inadvertently be harvested from time to time (real starvation). The on thing I know about biology after doing this for nearly twenty years: Biology is a goddamn motherfucker. It rarely does what it is supposed to do.![]()
