Fritzo
- Jan 3, 2001
- 41,920
- 2,161
- 126
is that before or after you soak it in A1 sauce for an hour?
Dirty secret: I love A1 sauce. It's actually very complex.
+1. Tried a couple lesser brand knock-offs of A-1 they use too much vinegar.Dirty secret: I love A1 sauce. It's actually very complex.
For clarification: I put salt on it liberally than let it sit for 45 minutes, at which point I use the sink to wash it off? Then I put salt on it again after it's done baking in the oven? (is this thing going to give me a heart attack?)
Lastly, at that temp, about how long (on average) does it take to reach 120 degrees? I'll check the internal temp to be safe, just curious as for when I should turn the stove on with the skillet as the apartment fire alarms get feisty when it comes to smoke.
Why am I not crazy about sirloin? Too lean. No matter what I do with it (grill, pan, broil), always comes out a little dry if not a teensy bitter? Never tried Sous Vide, pressure cooker, or other low-slow method. Is that the secret for super lean sirloin?
BTW- I've graduated from plain old steak and been getting into making beef Wellington lately. Here's my last two results:
Only extra virgin olive oil has a low smoke point. Lower grades are fine for high temp cooking
Speaking of I want to try safflower oil next time. I don't cook so much and the longer shelf life, high smoke point, fairly health and neutral taste seem ideal.
looks awesome...how did you make it?.... is that puff pastry you use on surrounding the beef?
?It's a beef filet (it's a whole filet mignon). You can actually but a whole beef tenderloin for under $50, and separate it to get your our filet out of it (plus get a nice flank steak or roast for later!): https://www.youtube.com/watch?v=tf9K0D-fnnM
You won't get a flank steak from breaking down a tenderloin. Flank steak comes from a different region of the animal.
Gotcha. Do you do the same thing I do and remove the lobes on the butt end of the tenderloin? While I don't necessarily find them tough they don't actually have the same flavor and texture of the chateaubriand portion. You can salvage some meat from the chain too, but it's not very much; what you can get is damn tasty though.It's just a general term for tough steak. Yes, a proper flank steak comes from the bottom of the cow, but the texture of the muscle surrounding the filet is very similar and you can use it as a substitute.
Sous vide has a hard time getting a good crust, and I like a crispy crust, so when I do steaks at home these days, I use the Namath. If I'm at a friend's house & they have a well-ventilated kitchen, I do Alton Brown's cast-iron pan method.
That is why you sear afterwords. Sous vide until it is perfectly cooked and then Alton Brown cast-iron sear
That is a lot of salt.......salt your steak liberally for at least 45 minutes.
