Is there another name for SMA connectors? I would have assumed radioshack would have them, but nothing on the radioshack website is close to 'SMA'. is there a more technical name or perhaps radioshack just doesnt carry them?
I found an adapter that is female RP-SMA to N female on a website for 5.99$ but the website has a $100 minimum. I have the part number, but no other place i can find carries that part number or a similar item
you will have to get lowloss cable and cripers also not a cheap propisition or just call Hyperlinktech and ask for Sergio he will explain custom cableing and will make what ever you want for a fee.
