In the Department of Engineering Science at University of Oxford where I was working for the month of January. If anyone should know how to brew tea in an intelligent, safe manner, I would think they would be the ones, but perhaps you know better. They had both free-standing kettles and wall mounted designs, both of which were closed systems with thermal controls similar to those I mentioned.Where did you see such electric kettles? If such a kettle existed, I would be shocked at the utter stupidity and dangerousness of the design.
I get nothing with that link. And whats with the dynamitedata crap?
I'm not familiar with tea brewing I suppose, but I had assumed the water wouldn't be boiling, so the pressure would be fairly low (with an upper limit of atmospheric pressure + the vapor pressure of water at the setpoint temperature).
I don't drink coffee or tea (I find the smell, taste and caffeine unpleasant) so I was unfamiliar with the meaning of air pot. It would be complicated to have a vacuum insulated chamber and a heater heating the chamber contents at the same time. Have you seen a air pot with both?
I just got back from the UK, where I was working on a project that required me to design a small climate control chamber. I mention being in the UK because they use lots of electric "kettles" there for tea - just a 2L plastic pitcher which heats up the water pretty quickly. I am not a big tea person myself, so I'm not sure if it's actually temperature controlled, on/off, or even always on.
The system I actually built was designed to maintain body temperature. I achieved it using a simple on/off control algorithm. I modeled the system in considerable detail to arrive at the conclusion that this approach would work, and I can summarize them as follows:
1. The heating rate is small relative to the thermal mass of the system (or the temperature sampling rate is high relative to the system's thermal equilibration time at a given heating rate);
2. Heat transfer within the system occurs at a rate which is high relative to the heating rate (i.e. the system may be considered "well mixed") or, if not well mixed, at least you can estimate the thermal energy of the system based on measuring the temperature at one known point; and
3. Thermal losses are small relative to the heating rate (i.e. the system is "well insulated").
If these three conditions are met, which they probably are in your system, then an on/off temperature system would work well. It's quite easy and cheap to measure the temperature to a suitable degree of accuracy. The method I eventually settled on is simply to compare the temperature sensor output to a reference voltage using a comparator. If the temperature voltage is higher than the reference, shut off the heater; otherwise, keep heating. The reference voltage will depend on a few things, but it will probably be easiest to simply find it by trial and error, especially if the system is not well mixed. You can get an idea for what kind of heaters you need based on your approach #2 above, which is exactly the way I approached it.
All the air pots and kettles that I have seen that have temperature controls on them will always boil the water first and then let it cool down to temperature and then use the heating element to maintain the temperature as needed. This is particularly necesary for areas where it is recommended or required that you boil water prior to consumption. My only complaint is that my air pot loses heat so slowly that I have to open it up for the water to drop down to temperature in a reasonable amount of time.
I want to have a serious discussion about what the best design to heating water to specific temperatures. As a bonus we can also discuss maintaining that temperature. The reason this is important to me is I am a tea (and coffee but to a lesser degree) snob. I care about how many grams of tea I am brewing, what temp the water is and how long.
We will be focusing on electric kettles because they are convenient and heat up fast (efficient). They also don't require a stove, something I don't have access to at work. There are some variable temperature kettles on the market and I had the T-Fal one but found that it really did not heat up to a range of temps. Instead it was either 200 from the 0 position up to 50% then 212 the rest of the way.
I am not a physicists but this is how I imagine you could solve this problem.
1. Use a PID. Basically you know how much heat your element produces and you keep a thermometer inside the kettle. When it reaches that temp, you shut it off and sound the audible alarm.
2. This is more complicated and I am not sure how it'll work but here's my idea. The kettle has a known weight (empty) and since it must sit on the base/dock to heat the base can measure how much water is in there based on the additional weight. Water weighs about 1KG per litre so you can extrapolate that. Then you know how powerful your heating element is and you can figure how much long it needs to run to heat up that much water to a certain temp.
A kettle I am using holds 1.8 litres and has a 1500 watt element.
1.8 L = 1800 grams. A rise of 70F - 200F converted to C is 72.22 degrees.
1800 x 72.22 = 129,996 calories
129,996 x 4.184 = 543903.26 joules
543903.26 joules / 1500 Watts - 362 seconds
362 s / 60 seconds = 6.04 minutes
Since kettles specifically tell you to only put water in it, we are not concerned about the calories of other liquids such as juice or stock.
Is there a different way this can be done? Can anyone suggest a different kettle design?
That is, whatever electrical energy is actually delivered to the element will ALL go into the water.
By far the largest impact on "Efficiency" in this system is NOT Efficiency of the heater; it is heat loss from the hot body (kettle), which depends on how much insulation surrounds it.
Bah, forum nuked my original response so here's take two.
Sure, the one that I have features both:
http://www.panasonic.hk/ha/english/feature_585.aspx
http://www.sonicelectronix.com/item_21235_Panasonic+NC-HU401P.html
VIP is their catch-phrase for vacuum insulation. There are other air pots that I have seen in the store that are vacuum insulated too. I really like this one, just wish it could take in both 220 and 110 V.
No. You've decided that science is somehow a matter of opinion, that everyone else here is a layman, and that you already know the answer to a design question which has many answers.Can you describe the kettles in as much detail as possible?
Canis, yes, the term "PID Loop" is used widely to refer to a feedback control loop with these three terms in its operation - Proportional, Integral and Differential. However, that form of controller is SO common that the term colloquially has been used as if it were simply a synonym for any feedback controller. It also is a type so widely sold and supported that almost nobody makes a less-capable "just Proportional" controller any more because including the other two functions in a mass-produced controller makes more sense that producing and stocking separate products. Besides, it is very easy with any modern PID controller to simply not use the I and / or D functions and achieve a "just P" control if that's what you need.
My father was an instrumentation specialist back when controllers were analog pneumatic devices and the most common type was "just P". On them one adjusted the Setpoint and provided a pneumatic Process Variable signal (3 - 15 p.s.i. air pressure) and it produced a 3-15 psi output air pressure signal to route to the actuator device. Most had manually-adjustable settings in them for Gain and Damping, and they often were built as a recording device, too, with pens writing on strip or circular charts. The addition of Integral and Differential capabilities (not easy with pneumatic air pressure as your means of calculation over time) was real progress and got a lot of attention. As the transition to electronic controllers, sensors and actuators replaced those systems, it just made sense to replicate the full capability of the PID systems.
Regarding Efficiency, it happens that's an old discussion point dating back to my first-year university Physics labs. Any simple resistive electrical heating element IS 100% Efficient - ALL of the electrical energy supplied to it, being the product of voltage x current x time, is released into the surroundings as heat - there is NO other energy flow anywhere else. I quite understand that the overall device MAY have places where electrical energy is wasted - for example, in a poor connection in the plug of the kettle cord, leading to heat wasted there and not delivered to the water - but if you examine ONLY the energy that actually does arrive at the heater terminals, it ALL gets converted into heat in the kettle's water. Thereafter, much is lost outside the kettle, but that is an impact on the overall system operation, not on the "efficiency" of the heater itself.
Now, in the case of a "steamer", I presume you mean a device which heats water to boiling and then releases that hot steam into the air or into some further process. The fact that the hot steam that leaves the steamer vessel takes heat energy with it does not reduce the device's efficiency. That hot steam is part of the output and therefore must be included in the efficiency calculation of (energy out) / (energy in). Moreover, the "energy" in hot steam is not just in its temperature, but includes also the Heat of Vaporization it carries by virtue of having been converted from the liquid to the gaseous physical state.
I maintain in ALL cases the "Efficiency" of the heating element is 100% - that is, if you accurately measure the voltage being supplied to the heater terminals, the current flowing through it and the time it is powered on, ALL of that energy will be converted into heat in the water. BUT, if we consider instead the "Efficiency" of the entire kettle - voltage, current, and time measured at the kettle plug's blades - then my reply to your cases is:
a.) Zero heat loss in any form, it's 100% Efficient. That ultimately will change, though, once you get all the water to 100C and start converting water liquid to stream - you will either lose steam from the system right away, or will build up pressure in a closed container until something blows up!
b.) 1500 W input, 750 W heat loss rate, the system is 50% "Efficient" in terms of delivering heat to the desired point (hot water still in the kettle ready to use); half the energy input is "lost" to surroundings and not usable.
c.) Steam Maker using 1500 W power input with zero heat loss from itself, but allowing a continuous flow of steam to exit, carrying 1500 W heat flow with it: that also is 100% "Efficiency" because the heat ALL is being delivered to the intended point (hot steam for use elsewhere) and none is being lost to surroundings.
Now it comes down to what you want to do with the device, which will lead to what your definition of "Efficiency" is. I'm suggesting that if "Efficiency" generally means (Energy delivered to an intended use) / (Energy input to the machine), the "intended use" part is the key element in the definition.
Now, IF I accept that I want humidity AND heat delivered to the room, PLUS I also contend that hot water to make tea is a desired use, then every one of your cases is 100% efficient in delivering energy to where I want.
In cases 2 and 3, suppose we are in a very warm room and are using an air conditioner to cool it down, but we really do want the humidity because this is Arizona with hot dry air outside. In those cases you could take two views. One might be to say that the heat delivered to the room is NOT part of our desired use, and hence "wasted energy". That will lead to an "Efficiency" less than 100%. Alternatively I can take the view that Efficiency still is 100% in terms of converting all electrical energy into heat energy that enters the room; however, I have an additional but separate task to reduce the room temperature which will involve use of another system (an air conditioner) requiring further expenditure of energy.
This is a good example of a general principle. People use words and language to communicate concepts. When there is complete agreement on word definitions and language structure, the communication can be "100% Efficient". However, lots of times that complete agreement is missing BUT presumed to exist, and mis-communication results. My own pet sub-topic of this is, in fact, the use of "percent". I ALWAYS want to know, "% of what?, because the item after "of" is the denominator in calculating the % number. In the current discussion, we also are clarifying what goes into the numerator in order to understand each other's true meaning.
