- Jul 11, 2001
- 40,874
- 10,222
- 136
I have a torque wrench, had it a long time, don't know if I've ever used it, in fact. I thought it was for torquing wheel lug nuts. Can I use it on the drain plug? Am I looking to get a specific torque? I can still crawl under the car and tighten that drain plug... The torque wrench is 1/2" drive, has a scale on it, it's totally analog, goes up to 140 foot-pounds. Don't know how high I could crank it! Gotta see if I can work it with an 11/16" socket somehow.Yes, that Mobil 1 Full Synthetic is a Group III+, it's a good oil but it ain't no PAO Group IV oil. As for the oil drain plug, though you really should use a new washer when replacing it, I'd say the most important thing you can do is use a torque wrench when tightening.
Edit: Looking, I see I have 11/16, 3/8" drive sockets (short and long, although I used a box end wrench the other day). So, to use the torque wrench I'll need either a 1/2" drive 11/16" socket (assuming that's the right size, I guess O'Reilly can tell me from their data lookup), or get a 1/2" to 3/8" adapter. What torque do I want?
Edit2: I'm definitely going to have my AC diagnosed professionally.
Edit3: Actually, I have the previous drain plug and a couple of sockets that would seem to work. I used an 11/16" box wrench the other day but the 1/2" 19mm and 3/4" sockets I have seem to have a decent grip on the plug. Presumably I can use either without stripping the plug, or does it matter that I use the proper socket, whatever that is? Online it says that 3/4" is approximately 19mm so guess it doesn't matter which I use.
