Originally posted by: spidey07
Why not install a proper ground now that you have the opportunity? 8 foot rod, busbar, 6 gauge wire, all that jazz.
As long as it isn't lightning you should be fine, but I'm not an electrician so more knowledgeable will have to address that.
Feels like 13°F
Feels like 13°F
Feels like 13°F
Hehehe.
Well, I've spent a lot of time working with house common ground wires while the power was on and I've never been electrocuted, but I'm sure the smart thing to do would be to cut the power and get a flashlight with a battery pack.
See topic, the ground wire is in a bad spot and it would be immensely easier to have some good lights on to see what I am repairing, but I am sure I should kill power first.
Why not then ground twice, then remove the old one?
Originally posted by: Rubycon
You live in Michigan with no backup genny and decent flashlights?
Grounds are supposed to be at zero potential. But that's not always the case and there's probably some potential. Either way bond with a small drain wire - 14AWG is sufficient so you don't get tickled.
It's only when you're dealing with very high voltages you have to worry about induction!
Text
