Magicka - a few questions
@CPA
I saw others mention "macro tools"... and thought Id share this:
its called "X-Mouse Button Control".
Basically it has "5 layers" (profiles) that you can asign or manual load before doing a task like playing Magicka.
If you leave left and right mouse button as is, you still have:
Mouse button 4
Mouse button 5
Middle button
Wheel up
Wheel down
(or more depending on what type of mouse your useing)
^ say 5 spells you could make macros for (most cases for people with normal mouses).
You use the "simulate keys" for each and define what that macro needs to do.
Its all in a single line, but it has room for like 2300 key signs, so you can do some really complex stuff if you wanted to.
Doing something basic like:
qqqqq then shift+m1
would be:
Q{WAITMS10}Q{WAITMS10}Q{WAITMS10}Q{WAITMS10}Q{SHIFT}{LMB}
(edit in the shift part, theres a space, thats not supposed to be there (between the F and T))
You make the macros you want, for the mouse buttons you can spare playing it, and then put it on a layer (profile) and load that profile before the game.
Now you do spells 10 times faster than a normal person, flawlessly and by only 1 button.
