- Feb 17, 2021
- 3
- 0
- 6
My Macbook pro 2011 was water damaged, i ended up fixing it. It started working and it ended up being that the battery was fried. i would disconnect it and the Macbook would run on full speed.
I ended up getting another battery and it would work but the trackpad and keyboard wont work, only on the login screen and when i login it would stop working, i tried restarting the SMC and PRAM nothing happened.
Now that i got the new battery the whole thing wont turn on. battery unplugged nothing, the charger shows a dim green light, anything i can try doing? Cheers!
