TreVader
- Oct 28, 2013
- 2,057
- 2
- 0
wtf? They are two different classes of machine. To even try and compare the two is just flat out idiotic.
Why? Because it makes the macbook pro look like nothing more than a better screen (which, admittedly, is amazing but...)?
The 13" macbook pro should disappear and they should add the retina to the air. Nobody need a slightly higher processor clock. Benchmarks show that because the MBA has turbo frequencies similar to the rMBP 13 they perform basically the same.
The only difference beyond the screen is the air is lighter and has much better battery life.
The 15" pro gets the same battery life, has a better screen, is also very light (but no MBA light), and performance wise it totally eclipses the 13"..
As far a the OPs question
YES 4GB will work, but you want 8GB. I had 4GB in my MBA and it would've been nice to have 8GB. I certainly wasn't wondering why I payed the extra for the 4GB vs 2GB.
