Steltek
- Mar 29, 2001
- 3,309
- 1,046
- 136
By coincidence, I was just looking at some LSI 9300 cards this week since they are both so cheap and available on eBay as I'm thinking about building a NAS/Proxmox server. Was doing research to see if there are lots of reported problems with them (I wasn't interested in RAID, only in using them as an IT mode HBA for refurb data center SATA/SAS drives).
From what I recall (I think it was in a thread over in the Level1techs forum), I believe it actually is required due to the actual power requirements of this card.
The LSI 9300 16i is an x8 card (it actually has two 8i chips welded together under that oversized heatsink) so it requires more power than an 8i card.
Per the user guide, the board requires 26.9 watts of power to function properly. A PCIe x8 connection can only deliver 25 watts at the motherboard socket. This remains true even if you plug the card into an x16 slot due to the x8 LSI card not having x16 power traces. So, they designed the power circuit to draw the additional power needed from the PSU via a 6 pin power connector.
Now, whether this helps your situation or not, I don't know. I agree though since ASUS told you it wasn't compatible it isn't worth wasting time on. However, I mainly pointed this out to indicate that the card might not be defective. It sounds like a kluge of a design for the board, though.
Edit: According to the card user manual. The auxiliary power connector needs to be used "if auxiliary power is required for your system design".
So, it may be an issue on some systems but not with others.
Here is a link to the user guide.
BTW, the LSI 9305 -16i (which is more expensive on eBay, probably being due to it being a newer card and also offering SAS3) only requires 16.2 watts per its user guide..
