LS7 + Solstice = OMG
fbrdphreak
17,555
From C&D article:
If 400 horsepower is not enough?and when is it ever??Mallett can add a supercharger, a 505-hp Z06 engine, or whatever you want.
Sounds like this may not be too new ;)
Hot, but damn the wheelspin
RagingBITCH
17,618
I really do wonder how they plan on getting traction. I mean that looks completely bad ass and all, and GMPD is helping with all aspects, probably including new suspension and all that, but that's still a ton of power to be putting down in a lightweight car.
ElFenix
102,402
8,574
traction didn't stop carol shelby
arcenite
10,660
7
It is only 300 lbs lighter than a z06
mercanucaribe
Banned
Oct 20, 2004
9,763
I don't understand why traction would be a problem. It doesn't have as much downward force, but it also has less mass to move than a bigger car. Those should even out.
Mar 11, 2004
23,444
5,852
Downforce will only come into play at higher speeds, and less downforce means less traction (although too much downforce and cause negative affects to handling as well). Less mass also means less traction.
It won't even out, as both of those would have a negative affect on traction.
Relatively narrow tires, light weight, and high power, means low traction.
I'm not sure why everyone is making such a big deal about traction. The whole point of cars like this is to have fun when losing traction. I mean, you're not going to be bragging about how your car takes the twisties in a car like that, you're gonna say how fun it is to do power on oversteer slides around corners and how it accelerates.
Throw it into a tall gear, you're going to have plenty of torque no matter what gear with an engine like that, and then drop it down to second when you need to accelerate.
If you want traction/handling, you're not going to be looking at a high horsepower lightweight roadster, you're gonna be looking at something like the Lotus Elise or going AWD like an Evo or Porsche Turbo. You will get nice handling but thats from the low weight and far from bad supsension/wheels/tires, but its not going to be better than a car of the same weight that has better balance between power and handling (unless you do something like use traction control or limit the revs so that it doesn't hit the meaty part of the powerband).
Strk
10,197
4
That is a seriously ugly body kit.
nice stats.. but 50k for a solstice yikes... nice car though.. makes me wanna buy one and mod it. sounds like a fun car
That's about the same price as the convertable Corvette.
b0mbrman
29,470
That's about the same price as the convertible Corvette.
...which would outhandle this LS7-powered Solstice all day long
CVSiN
9,289
""We?re not complaining. The Mallett makeover proves the Solstice chassis is up to the task of handling V-8 power. It retains the Solstice?s buttoned-down feel and goof-proof handling. You have to be a lot more careful with your right foot, but otherwise, it handles just as sweetly as the stock Solstice. Lateral grip was way up to 1.02 g from 0.91. The brakes, though, need more development, because even with the grippy Michelins, the stopping distance from 70 mph was three feet longer than the stocker?s (177 feet versus 174), and the pedal didn?t feel as firm as it should. Mallett says a fix is in the works.
We didn?t detect any one area where the Mallett car felt like a hacked-up engine swap. The exhaust note had that V-8 burble but was quiet while cruising, and even the clutch effort was light.
For $52,585 you could buy what is in many ways a V-8 Solstice, the Chevy Corvette convertible. At 3300 pounds, the Vette may be commendably light, but it still feels about 50 percent larger than the Solstice. When it comes to curvy-road fun, many of us would pick the Solstice over the Corvette, and with Mallett?s Solstice, there?s the added fun factor of serious oomph.
If 400 horsepower is not enough?and when is it ever??Mallett can add a supercharger, a 505-hp Z06 engine, or whatever you want.""
actually the mallett solstice pwns the vette even in handling... and 1/4 mile..
http://www.caranddriver.com/specialtyfi...le-mallett-ls2-v-8-solstice-page2.html
