- Dec 19, 2008
- 653
- 176
- 116
Hey all,
My laptop gave up the ghost after I dripped fluids into its keyboard and things started to not work anymore, USB port here, keys there, etc. So time to replace it. This time with a desktop, so I can service it in the future instead of total overhaul like this when it happens again.
This PC lives in my observatory. It's duties are to run Windows (7) and it will power software that operates my observatory mount, planetarium software, video capture software and data capture software. None of it is particularly heavy stuff. The video capture is the heaviest stuff, and it will max out what's possible on USB3 bandwidth with my CMOS USB3 cameras. The rest is easy to run on virtually any hardware. I need fast USB bus though. It will be writing its RAW data feed to a 1TB SSD (Samsung). I was going to build around the latest AM4 3000 series APU's, but the Athlon went up in price a lot and/or is backordered. Either way, a newer motherboard is needed and RAM serves as the video buffer, so I'm happy to put 16Gb of DDR4 into it. That's just to help provide context. I already have the other things that will be needed (case, PSU, etc). So the goal is maybe an APU, 4c/8t class CPU with 16GB RAM for the above purposes.
I'm not sure what will work, as I'm familiar with the latest AMD stuff, but not the yesteryear stuff.
My goal is around $300 USD to rebuild the main parts of this (motherboard, CPU/APU, RAM).
Here's what I'm currently looking at, but I'm open to suggestions and pointers as long as we can stay in a similar price range.
AMD Ryzen 5 3400G (4C/8T APU) - $140
MSI ProSeries B450M PRO-M2 Max (B450MPM2MAX) - $75
TeamGroup T-Force Vulcan Z DDR4 16Gb (8x2) 3200Mhz CL16 Memory - $58
That's $273 currently. Will use stock cooler.
Any ideas to have any significant improvements for similar cost? Especially considering the above motherboard & memory? Up to the $300 USD mark roughly?
Thanks!
Very best,
Thanks!
Very best,
