- Oct 12, 1999
- 2,050
- 2
- 81
I wanted a quiet system so i wanted to use the lowest voltage I can and still achieve decent overclock:
19x160 = 3ghz
33mhz PCI
HIGH strap
CPU:RAM 4:5 --> 160:200
Vcore: 1.325 (1.28 actual)
1.7volts on the RAM
ram settings: 2-5-2-2 PC3700 Buffalo BH-7 chips
What other settings do I have to worry about? These are my benches:
MEMORY Bandwidth
INT BUFFERED 2980MB/s FLOAT BUFFERED 2983MB/s
CPU Arithmetic:
Dhrystone ALU 7926MIPS
Wheatsone FPS/iSSE2 - 1751/3920
CPU Multi-Media Bench: 12102 and 15418
These scores are low aren't they? What am I doing wrong?
Please help. -- I bought this oc'ed rig from someone that was running it at 3.5ghz. I just lowered the settings a bit. Did I miss anything? Or did I set something up wrong?
Thank you.
David
19x160 = 3ghz
33mhz PCI
HIGH strap
1.7volts on the RAM
MEMORY Bandwidth
CPU Arithmetic:
Thank you.
David
