Low Power Graphics Card for Corsair 450vx
crisscross
1,598
I have a Core i7 860 setup running on a Corsair 450vx and I am looking for a low power graphics card.
I don't game much just the occasional COD. HD Playback is important and I would also like to connect it to my TV at some point.
What would you guys recommend?
Thanks!
RussianSensation
19,458
765
I second the HD5670, but not that particular one. As was pointed out to me when I recommended it to someone last week, it has display port rather than hdmi, so it's not as useful for televisions, which the OP mentioned.
Good attention to detail. I didn't notice that. :thumbsup: Although, you can just get a Displayport to HDMI cable for $8.
RussianSensation
19,458
765
Thanks for the suggestions guys. Will the card be noisy with the two fans?
Here is a Sapphire HD5670 with 1 larger fan. This card has an HDMI and a Displayport so you have 2 options. If you already have an HDMI cable around, you won't have to buy a Displayport to HDMI cable. At Monoprice.com, an HDMI cable is about $3-4, which is also about $5 cheaper than the Displayport cable.
At checkout enter coupon code: superhot
for $5 off. With rebate, this card comes to $56 with shipping.
BFG10K
22,709
3,000
That’s a decent PSU that will have no trouble giving its full rated supply. PSU requirements tend to be overblown anyway:
That’s a full system load in the worst case scenario (i.e. Furmark), and still plenty of configurations are under 450W.
Ancalagon44
3,274
202
What BFG10k said. Even assuming 70% efficiency, you could easily run a 5870.
Anyway... a GTX 460, 5670 or 6670 would get my vote, depending on your needs. How much gaming do you do exactly? You could even get by with less than a 5670.
crisscross
1,598
Thanks guys.. Hardly any gaming at all. In fact I am only now playing bit of COD World at War! I do hope to play the newer COD at some point though.
Pneumothorax
1,181
23
I would try to find a heavily discounted 5770 or even a 6870 would work fine with your PSU. It's a value PSU from a reputable manufacturer which should put out as much power as a 1000W Diablotek.
Termie
7,949
48
www.techbuyersguru.com
The 6870 is probably overkill for his purposes, but a 5770 is not.
Here's one for around $100 AR/shipping: http://www.newegg.com/Product/Produc...deon-hd-6570/4. It all comes down to budget. Either will play COD : WAW, but as for MW3, the 5770 is probably a better bet.
crisscross
1,598
Thanks guys.. I would probably keep the PC on for long periods of time so I would like the idle power consumption to be low..
Pneumothorax
1,181
23
Any of the ATI 5xxx/6xxx (save for the dual gpu cards) idle within around 10+ watts of each other. Nvidia GTX460 cards and newer cards released afterwards also have good idle levels.
Believe it or not, but a 6970 has a lower idle than a 5770. It's the load levels that make the difference. You're only going to get better idle levels on pathetic gaming cards like the Geforce 430 and 6450 cards.
RussianSensation
19,458
765
Either will play COD:WAW, but as for MW3, the 5770 is probably a better bet.
The problem with a $100 HD5770 is for $15 more you get > 50% more performance in the GTX460. Once the GTX460 is overclocked, it will be almost as fast as a GTX470 which is almost as fast as HD5770 in CF. So it's difficult to recommend an HD5770 for $100.
crisscross
1,598
Thank you for all the suggestions guys. I am going with the Sapphire suggested by Russian Sensation.
timma
170
Gigabyte 6670 OC 1G DDR3 with 10 cm large fan~
it's watt lower than DDR5 version.
