VirtualLarry
I have been kind of continuously running a bunch of builds through my mind.
I'm still using a Core2Quad Q9300, overclocked from 2.5 to 3.0. It's a pretty solid machine. Haven't really done any gaming on it, but I figure it should play BF3 (barely). I have a GTX460 1GB OC card from Gigabyte.
I saw this motherboard mentioned in a thread:
http://www.newegg.com/Product/Produc...82E16813157236
It's very cheap as far as Sandy Bridge motherboards go, but it seems decent as far as features and quality too. It's an ASrock, which I consider fairly decent, and it has SATA 6G on it, which is unusual for an H61 board. (Are they really using an H67 chipset on an "H61" board, or are they using a third-party SATA 6G controller, or does Intel sell "binned" H61 chips, that have working SATA 6G on them?) It also has USB3, but no motherboard header that I can see, just the two ports in the back.
I would pair that up with a G530, cheapest (half-)decent Sandy Bridge chip. Was thinking of a 2100 or 2105, but why bother spending the coin.
I already have plenty of 2x4GB DDR3-1333 kits of RAM, picked them up when Newegg had them for $35 each.
Basically, I don't game anymore, although I've considered starting to again. (I just hate having DRM on my system, it makes it feel so "icky".)
I DO do Distributed Computing. So my current quad-core + GTX460 is really good for that. I'm currently having a good time participating in the PrimeGrid race. I also tend to heat my apt in the winter with my computers. (Really!)
So I'm hesitant to replace my computers, for that reason. But I would like something new to play with (of course), and some SATA 6G ports would be sweet for a boot SSD, and possibly a RAID array of mechanical HDs. (Or maybe just JBOD.)
But my electric bill is pretty high, it was $150 some of the summer months, now that it's getting a little cooler, it was only $115 this month. A neighbor of mine, said his electric bill was $41. He doesn't own a computer, and doesn't run his AC. Whereas I kept my AC running pretty continuously all summer.
I was thinking of doing this to reduce my electric bill, but if I still participate in DC, then I would probably want a quad-core, for a decent score.
My other SB build idea, was to basically go all-out.
http://www.newegg.com/Product/Produc...82E16813157263
Asrock Z68 Professional Gen3 board (which went from $234 to $269, grr), and a 2500K or 2600K.
That would cost quite a bit more, and potentially use more power (under load, idle power should be similar), but would allow me to continue to participate in DC in the manner in which I am accustomed, and probably to heat my apt still.
The third option is the cheapest - don't upgrade. Wait for BullDozer, or possibly Ivy Bridge.
For BullDozer, I was looking at this board:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128508
And an 8120 or 8150.
The idea there would be strictly for Distributed Computing. I would put both of my GTX460 cards on there, and buy two more GTX460s, and turn it into a "Monster Folding Box". (Or primegrid.)
