abasoufiane
Hi everybody
I really hope you would help me with my problem here
My computer is a new build, the specs are in the sig and using catalyst 8.7.
i think i'm having low performance in some games and all i want to know is why, in Grid for exemple my card performes less than my friend's 8800 GTS 512, something is definitly wrong, we have the same CPU at stock and he has a ga965p ds3, so basicaly i should perform at least 20% better than him but in reality he performs about 20% better. what's the deal?
even in Solar empire he has a constant 60fps while mine drops some times to 54fps.
However in vantage things seem pretty normal, i got about 7800 while he got around 5500, in 3dmark06 i got 11800 at cpu stock and 13500 at 3ghz.
if there was a hardware problem wouldn't vantage and 3dmark show a poor performance as well? specialy 06 since it uses cpu as well.
if my PSU is really the problem for not providing enough power wouldn't overclocking the cpu make it instable since it's already in the edge at stock speed ? i overclocked it at 3ghz and there was no problem whatsoever.
this doesn't make any sense to me except if it's the drivers...
to sum up about grid performance in just one particular shot in the multiplayer menu:
Mine vista 64 : 106
Mine Xp 32: 115 (catalyst 8.6 hot fix)
HIM : 125 (8800 gts g92 512)
we are running almost the same resolution with same aa
mine 1440*900
his 1280*768
as you can see his resolution is even higher!!
In race , my average is 60 while his is 66
even in WIC i'm averanging only 30fps while he hit 38 same everything.
Please somebody should elighten me this problem. what the hell is going on?
no problems with temps. (using fan fix)
Thank you very much in advance
Mine vista 64 : 106
mine 1440*900
his 1280*768
