Zenmervolt
Elite member
Originally posted by: Marlin1975
less then $100 is a lot of money? There are many toliets that use the new design and work well.
And toliet makers knew for a long time low flow was coming. They fought it and then put their heads in the sand. It was not until Toto made a very simple desgin change and the low flows work just as well as before. Toto does not need the pressure assist and other things you bring up. They just did a simple redesign and it works. I know my new one uses this design and has never had any issue.
Compared to $20, yes, $60, $70, or $80 is a lot of money.
You call Toto's design change "simple". It's easy to call something "simple" after the fact. After all, the changes that the Wright Brothers made to the design of their aircraft's wings were technically "simple" changes. It took them a lot of work with a wind tunnel to figure out what to do, but the changes were still small and simple.
I'm also curious, when did Toto make these design changes? 1994? Or a few years later, which would mean that the technology was still immature in 1994 when the mandate took effect.
You also don't address the core of my argument: That the proper means of encouraging resource conservation is to increase the taxation of that resource rather than mandating items that use that resource more efficiently. Notice how much more effective high gasoline prices are at driving people towards both fuel-efficient cars and to more fuel-efficient habits. High gasoline prices do far more to reduce the use of gasoline than CAFE requirements do. Similarly, increasing the cost of water would do much more to drive the use of water-saving appliances and the adoption of water-conscious habits.
Increasing the cost of water would have driven people to low-flow toilets anyway and would have increased consumer options by allowing intermediate toilets. People who felt that 1.6 gallons per flush were inadequate might then have had the option of 2.5 gallon per flush toilets that they might have liked. This would have reduced the number of people clinging to the older 3.5 gallon toilets and could have reduced water usage even more.
ZV
