Question Low-end / mid-range gaming, Athlon 3000G or 3300X, with GTX 1650 D5 ITX GPU?
VirtualLarry
56,587
10,227
To get up-to-date, skip to post #28.
There's this MSI RX 570 8GB for ~$120 AR @ Newegg, only take a 6-pin PCI-E power connector, suggested PSU wattage 450W.
Then there's this ASRock RX 5500 XT 8GB card for ~$190, no rebate.
Which would be better for lower-end gaming, possible in a rig with a G3258 @ 4.0-4.2Ghz, with 8GB of DDR3, SSD.
What kind of games would I be able to play with that sort of rig? Anything modern at all? Apex Legends? Fortnight?
Magic Carpet
3,477
234
My question is, what CPU are they referring to, by "2 core Pentium CPU"? Are they talking about the G3258 there, or something newer, like a Skylake G4400, or even a 2C/4T Kaby or Coffee Lake?
Even an ancient Intel Core 2 Duo will run Fortnite at playable fps. Youtube it.
VirtualLarry
56,587
10,227
Then why was my buddy, complaining about "stuttering" in Fortnite, making the game "unusable", with a G4560 2C/4T 3.5Ghz Kaby Lake, Radeon 260X 2GB GDDR5, 8GB DDR4, and an SSD.
He did have it hooked up via wifi, somehow. I told him to wire it (router is in same room, even gave him a free ethernet cable), he never bothered.
VirtualLarry
56,587
10,227
LTT did a video on a Dell with an i5-3770, and upgrading it to be a Gaming PC, alone with benchmarks for the i5-3770, and a GTX 1650, and a GTX 1660 ti.
VirtualLarry
56,587
10,227
Well, Newegg had some "Factory Refurb" Gigabyte-brand GTX 1650 4GB GDDR5 cards, some ITX single-fan models for $119.99, and some dual-fan (with triple HDMI 2.0 ports, even!), for $129.99. Also an MSI Ventus GTX 1650 (no PCI-E power), and some GTX 1660 ti 6GB cards for $239.99 (dual-fan).
I didn't see the GTX 1660 ti cards off-hand, otherwise, I might have bought a couple of them, but I ended up getting like 4x GTX 1650 card, for between $120-$130 (plus tax). So I will be well-stocked for entry-level budget gamer builds. (Bringing back up my two ITX mobos with G3258 CPUs, they would probably be perfectly-good Fortnite boxes with GTX 1650 cards in them. I hope. :) )
If not, then I've got parts to build a pair of AMD AM4 Athlon 3000G (unlocked 2C/4T APU), overclock those to 4Ghz, drop in GTX 1650, should make a decent gamer box, if entry-level, for e-sports / Fortnite / etc. if the g3258 boards don't cut it.
VirtualLarry
56,587
10,227
Can anyone with experience comment on my plans? Is a 3000G, CPU-wise only, "enough" for Fortnite, etc.? How does a 2C/4T Athlon 3000G (preferably @ 4.0Ghz, but I'm not sure I can get there yet, haven't tried, and probably using the stock (65W?) heatsink, compare to a 4C/4T Haswell i5-4570/4590/4670/4690? For things like e-sports and Fortnite? (What's the new one, Apex Legends? How does that play with 2C/4T Zen+ Athlon, versus 4C/4T Haswell quad?) Both of these CPUs would be combined with my factory-refurb ITX-style GTX 1650 D5 4GB cards.
Or should I wait until I can afford a pair of 3300X 4C/8T 4.3Ghz Zen2 CPUs for those rigs? (I'm building two of them.) I think that those CPUs can scale up to an RTX 2080, potentially, and might be overkill for a GTX 1650 D5 card. Then again, they would be more future-proof, should the buyer of one of my rigs decide to drop in another GPU. (But the 3300X is another can-o-worms, sort of, because it's nearly to the price of a 3600, which is arguably WAY better, for another $35 or so for a 6C/12T CPU.)
