Loud PC while gamingand videos, need help
kipliq
84
Okay so the good news is my temps look good.
lian-li a05b
All cores
32 idle
42 load
MB
45
Harddrive
40 idle
50 load
videocard
64 load
3 Case fans all Yates
1 Noctua on the CPU.
My loudest part is my Corsair 550VX, anyway to keep it quiet. My guess is when I game, it's taxing the PSU big time so the FAN spins up faster. Since the case is smaller, I know that it traps heat. My issue is not the heat it more how loud the PSU get while I watch videos and game.
Any Idea's on keeping the PSU quiet?
kipliq
84
I have a vapor-x card very quiet. I even turned the fan to 0 and it's the psu fan cranking up.
Rubycon
Madame President
Aug 10, 2005
17,768
485
System specs?
A fan gets loud because the load is high. If this is bothersome you may need to swap out with a 750TX.
faxon
2,109
yea the best way i found to eliminate PSU noise is to just toss a higher wattage PSU in. running a 750w in my main rig may seem overkill even with an overclocked quad and a single GPU card (7900GT SC to 2900PRO 1GB to 9800GTX 512mb, take your pick), but it sure is a good way to make the PSU last longer and stay quiet on hot days
kipliq
84
Thanks, I'll be looking into a higher PSU in a few months. My hard drive is a first gen Sata and it's scores like a 3 in Windows 7 performance so I'm going to upgrade my HD then PSU. Anyone have a recommendation on the PSU?
aigomorla
21,067
3,574
budget?
also your hardware?
We cant recomend you a psu unless we know what its intended on powering.
kipliq
84
My Rig
PII 720 x3 BE oc to 3.5 ghz
1GB Sap 4870 Vapor-x
4 GB G.skill
2 80 GB WD HD - upgrading this this week to the WD Black 640gb
BonzaiDuck
16,617
2,023
My Rig
4 GB G.skill
I don't get it. The case at newegg comes stock with a Seasonic 550HT. Am I missing something here? Why did you replace it with the Corsair 550VX? Did you get the case somewhere without the bundled Seasonic?
Despite some good points for some Lian-Li cases, I'm not that fond of your mid-tower. It has 1x120mm intake, and 1x120mm exhaust. I think I'd like to see a second 120mm intake . . . . somewhere.
I have enough pressure inside my cases that air is forced through the PSU no matter what, and I never have a problem with fan-noise. . . .
Are you interested in modding that case? With another fan-hole where it might count for something?
zagood
4,102
Might be a good idea. Test to see if the same thing happens with the side of the case open, to check if it's specifically PSU load or PSU temperature. High ambient case temps can make a PSU fan ramp up all by itself.
kipliq
84
The PSU was very quiet when I had my x850xt installed. Temp are a little higher with the 4870. My case is an older one and did not have a seasonic installed. I would not have purchased a new PSU if I had a seasonic.....
kipliq
84
I would mod but I suck at cutting! I would like to add a blow hole but again I sucks at modding lol.
Eureka
3,822
I wonder if attaching heatsinks to the side of the PSU would cool it down any.
zagood
4,102
Test to see if the same thing happens with the side of the case open...
Yellowbeard
1,542
Let me know how the side door open works. I'd be surprised if you could hear the PSU fan over the GPU fan.
kipliq
84
Did you read at the top of my post that I check if the card was making all the fan noise and it is NOT making the noise. What I did was enable the ATI overclock in the CCC and turned the fan on high and then turned it all the way down so i can not hear the fan on load. That is when I discovered the PSU fan is loud. I have a vapor-x gpu which are quiet and very cool.
I will be testing if the PSU gets quiet with the side off and use a fan to blow air on the PSU with the case open. Let you know my results.
I don't just stake claims with out doing a few test myself before hand but if I need a 750wt PSU then I guess I'll have to purchase one. Sucks because I just purchased the corsiar 2 months back.
Anyone know if I'm putting to much power from my PSU?
Yellowbeard
1,542
No, actually, sorry, I missed that part about the fan test.
And, as far as power draw, this PSU is plenty for your rig.
If the fan is abnormally loud we can try replacing it if you like.
BonzaiDuck
16,617
2,023
It seems that for the past few years, my intention to get a PSU that is just modestly in excess of my peak wattage draw has still led to overcalculation. I tend to use the exaggerating Xtreme Outervision calculator and pck something maybe 35W in excess of what it returns, but I might have chosen PSUs with sustained peak outputs of 100W less.
The key thing: get something that has good benchtest reviews for voltage stability, AC ripple and other features, and get something that has the highest "80+" efficiency rating. The more efficient, the cooler it stays, and the less likely that the fan will spin up.
kipliq
84
It seems that for the past few years, my intention to get a PSU that is just modestly in excess of my peak wattage draw has still led to overcalculation. I tend to use the exaggerating and pck something maybe 35W in excess of what it returns, but I might have chosen PSUs with sustained peak outputs of 100W less.
Put very well. I look into purchasing a new PSU later in the year. Will just have to live with it for now.
It did not help with the side off. Didn't test the fan blowing on the psu.
zagood
4,102
As a last resort test to make sure it's the PSU, with the computer off, stick something like a popsicle stick or something else non-conductive into the PSU to keep the fan from starting, then start up your computer. If the sound is gone, then bingo, for sure it's the PSU.
Hate for you to save up money, buy a new PSU and then find out it was something else.
Possibilities include hard drives, optical drives, etc.
If it is definitely the PSU, get in contact with corsair support, it'd be a lot cheaper to RMA your existing PSU (which should be fine for your system) then buying a new one. They may even send you just a replacement fan, Silverstone did that for me a few years back.
