Lost a bunch of Space!!!!
dynasty
398
Ok, I used sequoia, and I found that there is a large file 388mb in my temporary internet settings folder, well when i go ther to find that folder, it isn't there, i search for it, it isn't there, is this a ghost file or something? This isn't all of the space lost, but could be the reason for losing so much I think. But i just can't delete it.
MrChad
13,507
Empty your Temporary Internet Files from within IE.
Jeff7
41,596
20
Either that or just delete the folder in Explorer.
Or, if Explorer doesn't want to get rid of it, use the command line. rmdir /s /q is a very powerful command - it won't wipe files in use, but it can wipe out entire directories and their contents, so use it carefully. rmdir /s /q "Temporary Internet Files" would be the command, assuming you're in the directory directly below the TIF folder. Some files may not be deletable right away - rmdir should report the names of these files. If you really want to delete these, especially if the big file is one of them, Killbox should do the trick.
dynasty
398
if i delete through IE, do I need to delete all offline content too? What does that delete, when you click the delete all offline content too? thanks
ActuaryTm
6,858
12
Disappointing that a thread such as this lingers when the third reply (given over a week ago) would have proved sufficient.
