- May 16, 2002
- 20,978
- 9,147
- 136
Back up now. I think a power strip died, and when my new on comes, the 2 computers will be back up. My ppd dropped from 41 million in F@H to 17 million. Should recover in a few days when the new power strip comes.
Weak/Old Breaker, Its easy, safe, cheap to replace if you know how.then the breaker blows.
What kind of breaker is it? Standard breaker, GFIC, or AFCI?Any experienced electrical people out there ? I appear to have a bad outlet, possibly was shorted once or ?? Any chance that can affect the whole circuit ? It works fine on the circuit until I put a load on a different outlet, then the breaker blows.
Yes. Mark with all the money you spend on DC, you should haveIf you're still having problems at that point you should call an electrician.
Or do like RedPandaMining did in his new "mining barn", and get some "SpaceGoats power meters w/30A 240V receptacles (twist-lock)". I guess the guy sells them? They give a constant readout of various aspects of the power, including current wattage / amperage draw, etc. Pretty neat-looking.get a 30 amp breaker, and run #12 wire, to a commercial 30 amp outlet. Problem solved.
All you need to do is times amps by volts to get your watts, and if you have like a kill-a-watt meter, you can see the wattage consumption. Add up the computers on the circuit and keep it under 10% of whatever breaker amperage you got in the fuse box, and you should be good, if not, you'll just trip the breaker and you'll have to move equipment around or add more another breaker.Or do like RedPandaMining did in his new "mining barn", and get some "SpaceGoats power meters w/30A 240V receptacles (twist-lock)". I guess the guy sells them? They give a constant readout of various aspects of the power, including current wattage / amperage draw, etc. Pretty neat-looking.
For AC voltage isn't their an extra part to that formula? I have a feeling that formula is only right for DC voltage.....All you need to do is times amps by volts to get your watts,
