Looking to upgrade
VIAN
6,575
with a 6600GT you can run it at 1024x768 with 4xAA and the preset High, which is the highest of all the presets. Although you can bump up the Image quality more, I haven't checked it out to see if it's worth it. The higher texture setting didn't seem to do much of anything. Anyway, utilizing these settings, you will get acceptable framerates. There will be some frameblur which looks like framerates are hanging around the 30's and maybe a bit lower and places where it gets unacceptable sometimes, but only for a split second where it might drop to 24fps. I had Vsync on too, so if you don't mind turning it off, it might help towards those issues.
128MB of VRAM seems to be fine for it, but if you want higher image quality using AA and AF and higher resolutions such as above 1024x768, then the RAM will certainly come in handy. But I doubt, you'll get a card like that for 200.
That 9800 pro 256MB is nice, but there is too much memory, you could get a faster card for the same price.
If you open the computer up, the powersupply should have a sticker on the side, or somewhere on it.
I agree with Pete on this.
cmitchell17
63
Ok this is what i Found out.
PC Output total 295.4 Watts Max
Are you sure that the 6800s and 6600s are better cards. Im looking to play battlefield 2 but i think that game needs ram not a top end video card.
cmitchell17
63
There is also the
5v 28A Max
3.3V 13A Max
12V 17A Max
12VSP 1.2A Max LSP Output
AUX 5VB 1.8A Max
12V 12VSP Total 209W Max
5V 3.3 Total 165W Max
PC Output Total 295.4W Max
That is the whole thing i didnt know if you needed the top part.
blckgrffn
9,686
4,345
www.teamjuchems.com
Look at the link in my post above! That is what you need! Buy it! 6800! Go, go, go! :D If you do buy a 9800 Pro, don't spend more than $130 on it! That extra memory is not that helpful! Trust us! If you want to see that memory put to use, you need to go high end, at least X800 or better. The way it is, you won't need that texture memory as the 9800Pro won't be able to draw them fast enough for good performance.
Nat
cmitchell17
63
Give me the exact name of what i need to get is it just 6800 becuase i see like 6800 LE and stuff like that. But that link you gave me that said 6800 it just went to a place 50 dollar cards not to 6800s
cmitchell17
63
IM going to order this but will my computer motherboad power supply be ok.
I have a sony PCV-RZ24G
I have a open AGP slot.
blckgrffn
9,686
4,345
www.teamjuchems.com
Yes, you should be fine. I don't know about the rest of your rig, but 17A on the 12volt rail is good sign. This is a big card though, so watch for interferance with HD's already in place.
Nat
blckgrffn
9,686
4,345
www.teamjuchems.com
That 6600GT that you found would also be a good bet if you haven't ordered that 6800 yet. If it is truly $140 rebate, that is good price for that amount of power, being only about $15 more than a 9800 Pro.
cmitchell17
63
I already ordered it for a totle of 192$ I have to get a job now if i can. Anyway thanks for everybodies help on this. The next thing I have to do is get more RAM I have 512MB right now anybody have any reccomendations.
Express saver was 5 dollars and i said for 3 dollars to rush process my order so hopefully i can have it by friday my birthday. Thanks for the help.
VIAN
6,575
Good choice on the card. A 6800 is a kick ass card.
It is recommended that you have at least 1GB of RAM. I have that and the game runs great, but I don't know on big servers. Your system might not support any higher anyway.
cmitchell17
63
How long will this card last me untill games start running pretty slow under normal conditions with high to meduim settings. How long will this card hold a good value also anybody here that plays BF2 give me a review on the demo.
