Looking to build first gaming PC.
Get this PSU if 430W is too slim:
http://www.newegg.com/Product/Produc...-016-_-Product
It should turn out to be $15 more.
So go with everything on the build above but change the PSU to that one?
Also, could I get some feedback on the networking issue. I re-read it and realized it didn't make much sense. I apologize. Do you need to have matching Windows 7 systems for the network to be compatible? As in 64bit desktop matching a 64bit netbook?
If you try and run a 64bit program on a 32bit OS it wont run, so if you want to share programs just make sure you share 32 bit programs only (64bit OS can run 32bit programs but not vice versa)
Yea, change the PSU to that. Overshoots your budget by like $5 though.
Are you looking to share applications or just files on the network? With the later it should be no problem; with the former I have no clue.
Five dollars over isn't bad at all. And I don't know if I'll be sharing applications over the network... but I doubt I will. Probably just files. I'll try to get 64 bit for both desktop and netbook.
I don't think there are 64bit versions of Windows 7 starter, but it should be no issue for just a home network. Definitely get 64bit for the desktop otherwise you won't be able to use half your RAM.
K. Good to know. I've been trying to learn about all of this stuff recently. It just makes the purchasing process a lot easier with people who already know what they're talking about.
On the subject of the netbook, most of the ones around $250 have 1GB RAM with around a 250GB HDD. Do you guys think this is all that is needed? Or should I splurge a little more and get 2GB ram with 320 HDD?
You could always drop down the gaming PC a bit to free up budget for your netbook. For example, you could get the 6870 instead and save $50.
You seem to be quite sharp for a to be College Student so best of luck.
Your plan is an excellent one IMHO.
Nothing of value to add to the always excellent suggestions provided here so just want to offer an overall congrats!
Thank you!
And I'm wondering if there is another promo code for the different PSU? The one that you put with the older PSU didn't work. Or if there are any other promo codes in general, that'd be cool.
Some of these might have expired BUT here is the list
10% off Plasma, LCD, and LED-LCD TV's: EMCKFJE22
10% off select barebones: EMCKFJE24
10% off ALL SSD's EMCKFJE23
10% off ALL blank media: EMCKFJE25
10% off ALL desktop memory: EMCKFJE26
10% off select Projectors: EPPRJAPR
10% off ALL samsung LCD Monitors: EMCKFJE27
10% off ALL air conditioners: EMCKFJE28
10% off ALL Upright vacuum cleaners: EMCKFJE29
10% off ALL Trendnet products: EMCKFJE32
10% off ALL ZyXEL products: EMCKFJE33
10% off ALL Corsair PSU's: EMCKFJE34
10% off ALL NZXT cases: EMCKFJE35
10% off ALL CPU coolers: EMCKFJE36
10% off ALL External enclosures: EMCKFJE37
10% off select RAID server subsystems: EMCKFJE38
10% off ALL Netgear NAS units: EMCKFJE39
10% off ALL Ipod Docks: EMCKFJE42
10% off ALL office supplies: EMCKFJE43
