Looking to Build a Gaming Rig
MegaVovaN
4,131
750TX is definitely better!
It has a SINGLE +12 rail which is better than 2, 3, or 4 rails, since you don't have to balance the load, just plug in however you like.
750 also has 6 more amps than 620 combined.
chinaman1472
614
Get 4GB (2x2GB kit) instead of 4GB. Even if you aren't using Vista 64 bit, the extra ~1.2 RAM will help out, and it's likely you'll end up upgrading to it at a later date anyway.
http://www.newegg.com/Product/...x?Item=N82E16820231122
The 3870x2 seems promising in terms of being the best right now, but there's a lot of speculation of what will happen in the next few months. I think the price on it is going to run $449, while a 8800GT will cost you $200 less and perform just slightly worse.
pcgamer321
179
I was thinking about getting 4 gig of Crucial anyway. I am planning on using Vista 64 bit.
Also since the 750TX is better, why exactly does it cost the same then?
MarcVenice
Moderator Emeritus <br>
Apr 2, 2007
5,664
The 750tx isn't 'better', it's equally good. The tx750 offers more power, the 620hx offers modular cables. Since 620w is overkill for your rig, and 750w is complete nonsense for your rig, I would go with the 620hx instead, because it's modular you will have less cable clutter in your case, which is good for airflow and simply looks better. Also, megavovans assumption that the 620hx is a multiple rail design is wrong. It's marketed as such, rather long story tbh, but it's in fact a SINGLE 12v rail. So 620hx would be my pick.
pcgamer321
179
well I'm closing in on a complete system.
Just need a few more parts.
Also is a sound card needed?
Also, what are some great optical drives?
pcgamer321
179
alright, well I think I am done. Can you guys look over it? Anything I should change, and counterparts I should consider?
Crittias
69
Looks like a solid build to me. You'll have to post some benchmarks. I'd be interested in how that vidcard does.
pcgamer321
179
The only thing I'm iffy on is the motherboard. Is it worth it for the price, or is there something better that I can get with that money. I have never used DFI before.
MegaVovaN
4,131
What DFI mobo are you looking at? As for alternatives, I've already posted them:
MegaVovaN
4,131
Oh, that's a pretty high end board, I was thinking you were looking at entry level P35 DFI board (BloodIron).
There are higher models of P35 boards from Asus, MSI, Gigabyte, Abit.
pcgamer321
179
Well I'm looking for a higher end type machine and then stick with it for a while.
What are some great alternatives in the high end sector?
PolymerTim
383
No personal experience here, but while I've heard that the DFI Lanparty boards are some of te best overclockers, they are also complicated with a lot more bios options than other boards. Some would argue that the difference all those minor settigns make is almost negligible in real world performance. So I think these boards were made for people who like having all the settings and like tinkering on a regular basis. There are many other boards that are simpler to use and still provide excellent overclocking for much less money.
abit IP35Pro
ASUS P5K Delux
Gigabyte GA-P35-DS4
There are even cheaper options out there, you just have to decide what features you want to pay for. Check out the motherboard thread on the anandtech forums.
