Looking for Surround Sound SetUp Help
note235
1,502
7
So I have around $250-$300 to spend on
Speakers and A/V Receiver
Olevia 247tfhd
Xbox 360 or Ps3
HDDVD A2
and thats it
I would like something that maximizes sound for that budget.
PurdueRy
13,837
4
You're stuck with a HTiB at that price point...it would be tough to get even a quality 2.0 setup at that price point. I would try to get my budget up to $400. Then the upper Onkyo HTiBs become doable.
SlickSnake
5,235
I like to hit myself in the head with a croquet mallet and down a few beers in one swallow before posting ... :p:beer:
note235
1,502
7
mistake
posted in the wrong forum, was reading something at AVSforums about 120hz
anyway
what is the cheapest, best bang for the buck receiver that can decode trueHD or what HDaudio there is
and what would these do?
http://shop4.outpost.com/%7B7c1VVwZqI5iG3VNbqcFSzQ**.node3%7D/product/4965501;jsessionid=7c1VVwZqI5iG3VNbqcFSzQ**.node3?site=sr:SEARCH:MAIN_RSLT_PG
can i buy 2 of them for front speakers?
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
Originally posted by: note235
mistake
anyway
The Onkyo 605 refurb from ShopOnkyo for $299 was the cheapest one I think I've seen. (Normally ~$400)
R300s are ok for basic floorstanders. If you're going to end up spending $300-$400 on just the receiver though, it would be a more balanced system with higher quality speakers.
PurdueRy
13,837
4
how good are refurbs?
should be just as good as their retail counterparts....some may say better because they have had their problems fixed.
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
will i really note the difference?
what is DD 1.5 mbs?
Are you talking about the difference between Toshiba A2's conversion of HD audio formats down to DTS 1.5 and the Toshiba A3's conversion of HD audio formats down to DD 640k?
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
the former
The former what? Use more words.
If you were talking about my post, I only made one question, not two, so I don't know what "former" means.
I mentioned DTS 1.5 and DD 640k
You asked about DD 1.5
What are you talking about?
note235
1,502
7
actually, what receiver would allow me to receive DTS 1.5?
is the difference from 1.5 to DTH noticable?
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Ok... well the Toshiba A3 converts HD audio to DD 640k and the A2 converts HD audio to DTS 1.5
Any modern receiver should be able to get you the DTS signal, but if you have the A3, that's not what it's outputting unless there's a DTS 1.5 track on the actual disc.
As for DTS vs. HD-audio, I wouldn't know, I'm behind the times :p
