Originally posted by: mjs22
OK...what memory would I get for the IC7-MAX3 one if I want to OC the hell out of my 2.4C?
The OCZ Gold stuff specifically the PC3700. I have the IC7-G MAX2 and am running at 275 1:1 with my 2.4C. If money is a concern then I would recomend the OCZ PC3500EL just make sure it is the EL (Enhanced latency) and that it is a Dual kit. I had trouble with Kingston. But the OCZ has been good to me. No need to wait for the ovepriced MAX 3 either. They both use a BIOS that is similar.
Originally posted by: NicColt
from the looks of it you won't be able to put a zalman on it either. I'm just guessing.....
Originally posted by: oldfart
$380 is an insane price for 1G of ram. I'd go for Corsair XMS for much less. There is also Buffalo Tech PC3700 @ Newegg for $100 a 512M stick. It is Winbond BH5 based which is generally very good. Not sure how it is, but the price is right.
People are getting too hung up on the big $$ ram. The performance difference is tiny. This includes 1:1 Vs 5:4 and fast and slow timings. You are talking about maybe 1 - 2% here in actual system performance. CPU speed is what you need to worry about, not memory.
Originally posted by: JackBurton
I agree oldfart, $380 is not cheap but I like to get every ounce of performance out of my machine when I build something that is going to be my main machine. The $100 sticks you recommend MIGHT be good, and they also may not. I don't want to spend $200 (512MB X 2) and it not perform at the level I expected it to. I'd rather spend $380 and know what my memory can do. To each his own, but I likey the EL PC4000.![]()
Probably the most misunderstood part about building a P4 rig is the memory. The need for high end memory has been highly overstated. Fact is, the difference between the big $$ memory and reasonably priced stuff will have an actual system performance difference of ~ 1%, or even less. Spending all that $$ on high end ram is by far, the worst bang for the buck you can spend on your rig. The Memory mfgrs have done a good job of hyping this stuff up with big sounding numbers like PC4000!!, and use synthetic benches like SiSoft to show large gains. Fact is, these gains are also synthetic. In real world benches, they simply aren't there.
Originally posted by: ronnuke
I happen to have just the setup you are referring to...(an IC7-Max3 and OCZ PC4000 Gold Edition 1024M (512X2)) I will be putting it all together on Monday or Tuesday and I will let you know if it is worth the extra $$$ or not. From what I have seen in some real world benches it should be spectacular. Wish me luck......
ronnuke let us know of the cpu, heatsink, mem and settings you'll be using.
anyone know if someone installed a Zalman on this beast yet. I know that someone installed a Swiftech MC 4000
