Looking for car audio
Why do some of these units say they play CD-R/RW but do not support MP3 or WMA? I thought CD's recorded in MP3 and WMA?
1. Jensen CD3610
2. Blaupunkt Montreal CD34
I don't recommend the Jensen. It is under $100, but that's for a reason. In addition, the input is RCA, so you would need a mini-plug to RCA cable.
The Blaupunkt has the mini-plug input, but it is on the rear. It is just a hair over $100, but it's a decent deck.
If you really need to stay below $100, find an older used Blaupunkt on Ebay. They use to make a bunch of decks with the input on the face.
Trevor
Thanks a few of these look pretty good.
Can anyone explain this?
No, songs are most definitely not encoded in MP3/WMA for standard Redbook Audio music CDs.
So if I burn a CD of mp3's using deepburner or whatever I could listen to it on a head unit that does not support mp3 or wma?
No that would not work. The head unit actually has to support MP3 or WMA in order for it to work. If a head unit says it supports CD-R/RW but does not say it supports MP3 or WMA then the only thing you can listen to are WAV files (structured as an audio CD).
