- Mar 8, 2004
- 416
- 0
- 0
1. What YOUR PC will be used for.
Light gaming like Rakion: Chaos Force, internet etc...just a do it all system but not looking for a FPS beast
2. What YOUR budget is.
Looking for preferably around 600 bucks
3. What country YOU will be buying YOUR parts from.
USA
4. IF YOU have a brand preference.
Which ever brand will overclock like hell and perform...probably intel at this point?
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Just a LCD
7. IF YOU plan on overclocking or run the system at default speeds.
Overclocking of course
Only thing i have narrowed it down to is a video card...which is probably the evga 8800gt...but i don't know how that will fit in with the budget so any advice is appreciated
USA
Just a LCD
