sdifox
It'd be perfect if it accepted digital audio.
there is a version that takes toslink/spdif input.
miniDigi option they call it.
Looks like the miniDigi has digital out, so it's not a DAC.
it is an add on card for the minidsp to provide digital io
http://www.minidsp.com/products/minidspkits/minidigi
I don't understand it, and don't know how much time I'm willing to invest. You've been helpful, but your answers are rather terse, so I don't think I can rely on you to hold my hand through what looks to be quite the learning curve. I do appreciate the info, though.
Recent attempts to utilize the onboard sound (ALC1150) has shown it to be inadequate even by my fairly low standards, so I don't have any reason to believe that an add-on card would be much better.
And you would be wrong.
so usb soundcard is not good enough?
It might be, I don't know.
OK, you say sound cards can be good, and I can't disagree because I haven't bought one in a long time. Regardless, I don't want a sound card. I want to move signal processing and amplification away from my motherboard. I hope you will be respectful of my wishes.
Uh an external soundcard has a DAC and is external to your computer case. What is the difference of a DAC that hookups up over optical vs a sound card that hooks up over USB? Its doing the same thing in the end.
The sound card will also have multiple line level outs and will solve your issue with needing 2.1 line level output. Personally, I think a PCIE soundcard would be fine, recording professionals use them, its a huge improvement over onboard sound, the noise is not an issue. But if you want it to be external of the PC case, then just get a high quality USB Soundcard, usually they will list the specific DAC chips they are using if that matters to you.
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102035&ignorebbr=1
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132073&ignorebbr=1
These two would do what you want and have high reviews and can playback 24bit 96hz. I would go with the asus since Ive had issues with my creative (internal card) drivers.
Yeah, maybe so. I might go DIY on this thing because paradoxically it seems that simplicity comes at a price! I don't ask for much functionality from this thing, a DAC, 2.1, which is a 2-way xover with summed lows, a pot for gain and some adjustment of xover frequency. That's all. I'll be damned if I'm gonna spend $1000 for that.avsforum or audioholics
Please elaborate. I know I need a DAC, but what relieves me of the need for some sort of crossover?Wouldn't it be easier, cheeper, and sound better if you split an analogue signal instead of digital? All you need is a DAC and another amp.
