lightpants
- Aug 13, 2001
- 2,452
- 0
- 76
pop-a-lock
I used to work for them, I could open your car in less then 8 seconds.
92 Buick Century=piece of cake
you need a sturdy hanger or metal rod and bend it to lok like this
l
l
l
l
l
l...........___
l...........l...l
l_____l...l
With the bottom being about 1.5-2 inches long and the hook part about 3/4 an inch wide
put it in the passenger side rear door, between the rubber and the window.
You will feel a springy rod in there, hook the springy rod and twist the tool you made, slide the tool and the rod toward the rear of the car. Have a friend look through the window on the other side and tell you when the lock button moves- it will take you a few min, but you can do it.
l
l
l
l
l
l...........___
l...........l...l
l_____l...l
