Originally posted by: ChoppedBroccoli
Yeah, the SQ of the Klipsch really suffers b/c of this...?
You guys are silly. Don't base your opinion on stupid responses in this thread. If you are serious about paying $200 - $300 for some nice multimedia speakers, then get off your butt and buy both systems from Best Buy and audition them in your HOME (not in the store, since subwoofers are never placed correctly at BB). I know if I were about to drop $300 on speakers, the least I could do is make sure I am going to be satisfied with them.
Both systems are great. Price shouldn't be a huge factor, since the difference is less than $50 and you will be paying $250 - $300. The Klipsch at Dell a few weeks ago were MUCH cheaper than this, but that doesn't matter either.
After deciding what speaker systems sounds better you have to make other decisions. Do you care about the remote/decoder, or will you be using this primarliy on your computer? If yes, do you want the remote/decoder included in the system or do you like the Klipsch enough to spend another $50 - $100 for decoder?
As for the reliability of these systems, I'd say its not a factor. The old Klipsch ProMedia 5.1's had an amp problem which was fixed and is no longer an issue with the Ultra's. Chances are the failure rates are somewhat equal for both systems.
LONG STORY SHORT: Before buying $300 speakers, don't listen to people on the internet, LISTEN TO THE SPEAKERS! (Lol, one would think this is common sense)
