Originally posted by: badmouse
Use match or lighter to heat key. That got me through a lot of wacky below-zero Ohio mornings.
Originally posted by: mobobuff
Heating the key won't do much good. He can already insert the key, but the tumbler is frozen to the inside of the lock casing.
Originally posted by: mcvickj
I had a similar problem this morning. Finally after getting the doors open I found out that I couldn't close them! The latch mechanism was stuck and wouldn't move into the close position. After a few shots of WD-40, a few choice words and messing with the inside and outside door handles I was able to get things working. I was just about to the point where I was going to say to hell with it and go back to bed. A hot bucket of water should do the trick.
I noticed your from Muskegon, Mi. I'm in Grand Rapids, Mi so I know what your going thru. Good luck.
He can put the key in and heat the handle (the part that sticks out) if it isn't coated with plastic.Originally posted by: mobobuff
Originally posted by: aircooled
hair dryer or heat gun..... do you have an electric heater??? grab an extension cord and heat he lock area..
lol, just do the same thing only with rubbing alcohol.Originally posted by: FrequencyX
I would recommend trying a bottle of Heet (The yellow gas additive) try pouring the bottle into a spray container and squirt some into the key hole.
Originally posted by: DaWhim
time for a keyless entry?
Anyone ever had the tumblers freeze w/keyless?
As far as I know, keyless entry systems don't actually turn the tumblers in the lock, they just trigger the solenoid to lock/unlock the door.
JW
Even if the tumblers are frozen to the mechanism, or whatever, the warm key will get it moving eventually.Originally posted by: Ausm
I used to heat my key up with a lighter and stick it in...it will work eventually.
Ausm
