Hi guys,
I have an Abit NF7-S Motherboard, AMD XP 2500+, 120GB Matrox SATA HDD
For some odd reason, I left my PC whilst extracting a .rar file. When i returned, I saw the logon screen and when I tried to login or press ctrl_alt_del, it gave a quick BSOD and restarted. It said something about 'kernel' in there i think.
So I restart my PC and it tells me:
Windows could not start because of a problem in the software.
load needed DLLs for kernel
I tried SAFEMODE first, with networking, without, and command prompt. All stopped whilst loading KDCOM.dll .
So I search it up in google and the best thing I find is that you need to repair your xp installation. Sounds pretty easy right.
So I fire up my XP SP1 cd and it loads the blue setup thing, and it tells me that I don't have a HDD in there, or it doesnt detect my HDD.
My HDD is SATA Matrox 120gb so ofcourse I would need the SATA drivers for the thing to work. So I download te drivers, put them on a floppy, and go through the setup again.
I pick the Silicon Image 3112 for XP driver and then I continue with the setup. I press R on the menu screen, and then in the bottm, it tells me "Examining 117240 MB on id 0" + alot of other stuff, but it stays frozen at that.
So then I tried loading my drivers in ERD and its the same problem, the thing won't load at all.
Now I have a SATA drive here that just can't be accessed by anything. If i restart, it tells me the error "load needed DLLs for kernel."
Just recenly (about a week ago), I replaced my CPU fan / heatsink with a new one, and I reset my bios. When I went into bios, I found out that in the boot sequence, when my HDD was listed as Serial ATA was now listed as HDD-0. I changed it, but it didn't make any difference.
Now, I am stuck and I dont know what else to do. I have another PC at home, and a laptop, but neither can read SATA harddrives.
What should i do?
What should i do?
