LMAO, some landlords are smoking crack
aceO07
4,491
Can you describe the damage that was done by your chair?
I put a plastic chair mat on my hardwood floor in my room at home. We've had the house for over 6 years and all the floors are still perfect (spotless/shiny) as the first day it was finished.
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
No, we put that the rug there when we moved in.
Fine. Regardless, if there's a conspicuous worn spot in the dining room, unless the previous 15 years worth of tenants also had chairs in that very same spot, then it's beyond normal wear and tear.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Be glad you're not living in Arizona. Here they can charge you for damage the landlord caused by knocking over a lamp, while raping your wife, which burned the place down. Renters are just plain screwed.
Eli
Super Moderator | Elite Member
8
Hmm.. The limit for charging for carpet is usually 2-3 years, AFAIK. I don't know what it is for wood floors, if it's even different.
Honestly though, wood floors should last many, many years... If your computer chair messed it up, I would say that's on you.
Why don't you call a few places and ask how much it would be to repair a section of wood floor, giving an estimate of how big the area that needs refinishing is of course. That will at least tell you if his charge is out of line.
Zebo
39,398
19
Landlords make good money niggling away security deposits and small claims may not help. He has a friend to write him an invoice for whatever he says to, you don't. Try and keep that in mind and be nice it might work best.
BUTCH1
20,433
1,770
When I used to rent I went around with a camera and took shots of ANY defect I could find, and then took photos again after I finished cleaning when moving out, always got my deposit back but a few times I had to keep going back to the Manager's office to "remind" then I wasn't going away, one in particular I visited every single day for 2 weeks before they caved in and cut me the check.
XZeroII
12,572
So the floor was in good condition when you moved in and was in bad shape when you left? Then why shouldn't you pay? Destroying a section of floor in 2.5 years is NOT normal. In fact, the landlord sounds like he's actually giving you a pretty good deal by splitting the cost with you.
I can't believe some people who destroy stuff and then don't want to pay for it. Unless you have pictures proving that it was already in bad shape when you moved in, you should definitely be responsible for the damage you caused.
vi edit
62,484
8,345
I think you'll pay. A plastic mat would have saved the floor.
Probably would have made it worse. Stuff can get under the mat and act like sand paper to the floors when it slides around a little bit.
jmagg
2,289
492
Been using one to protect my own hardwood floors, works beaut.
Gibson486
18,378
Unfortunately, if you do not have pics of what the condition was before you moved in, you may have a difficult case. "Wear and tear" in lots of states is a very vague term, but if you have no pictures to show the condition of the apt, it's difficult because now it is a argument based on what he said and what you said.
child of wonder
8,307
176
Most landlords are the real estate equivalent of serial rapists.
Best advice I give to people is to take meticulous photos of the place before you move in, give a copy to the landlord and write on the lease that you gave them to the landlord. After you move your stuff out, take pictures of everything again so there is a contrast as to how things looked before you moved in and how they looked after you moved out.
