LiteOn CDRW 52x
Originally posted by: LED
Any suggestion on cdrw for around 50?
Ipromisen you there is no better choice for that price today IM and many others O
wow I had to read that one about 3 times before I understood W T H you were talking about, I thought you were on PCP or something
Originally posted by: brentman
I have a Lite-On 48x and I am seeing very little improvement from my Plextor 12x. I'm talkin like 5-6 mins for a full CD. I think I should be getting better times than that. Should I blame the media? Perhaps the IDE config? VIA drivers? Its an XP 2000+ in an Epox board with 512MB 2700DDR. I can't even listen to my music anymore while burning.
Sucks to be me I guess.
why, is your system that slow? make sure dma is on. and they aren't on the ame cable.
something is wrong because even when i had my 48x lite-on in my old p3 866 with 384 of pc133 i was getting anywhere from 2:50-4:30, only taking 4:30 when i was putting hundreds and hundreds of small files on there.
bad drive maybe? I'll throw it in another system I have and see if I get the same slow speeds. I only have one HD installed currently and its primary master, cdrw is sec master. I shouldnt be having this trouble. :-/
Do the Memorex drives use the same firmware as the LiteOns? I believe the Cenodynes are rebadged LiteOns as well, but I've read that the firmware is different. Whether that makes much of a performance difference, I don't know.
What media am I usin? Stuff not suggested to be run at 48x I guess. I got some Memorex cd-r's tonite and got my time down to 3:40. Still lags up the machine pretty bad while burning tho. I should just get a copy of XP Pro and do it right, I suppose I could use a change from Win2k. Thanks for all your thoughts guys.
- Brent
Originally posted by: pillage2001
For you guys burning at 40X or higher with this burner, how high does the CPu utilization go?? Mine hits as high as 50% 🙁
definitely check to see if dma is turned on, same thing happened to me a while ago.
burnnig from maxtor 80gb to liteon 52x doesn't lag on my xp2000+. i'm using pos sdram too😛
should only lag if drives are on same cable. or if dma is off
its been nice and quiet compared to the pos samsung 48x i had just b4. no burn failure yet🙂
only pain is nero doesn't tell you the real burn speed. just have to sorta guess from time🙁 under 3 minutes is pretty nice. 24x rw with mt rainer makes the format finally useful!!
