n7
- Jan 4, 2004
- 21,281
- 4
- 81
Originally posted by: LOUISSSSS
20 times using what amount of memory would be optimal? i have 2 x 2gb with a 32bit OS
Originally posted by: VirtualLarry
Originally posted by: AdamK47
The temps don't get hot at all for me. The highest I've seen with this is 66 degrees and that was for a split second. Most of the time it was between 60 and 63. With Prime95 using 8 threads the temps are stable between 70 and 73. These are temps recorded with SpeedFan. Add around +10 for RealTemp temps.
I've noticed that too. I find it strange that some people claim that linpack causes temps higher than prime95, because I just don't see it.
Originally posted by: n7
I still cannot get over how insane this application is under max RAM testing with 8 GB...
I'm getting temps in LinX over 15C higher than with P95 small FFTs!
last time i used "ALL RAM" it gave me an error. i'm not sure hwy
my system passes 1024mb ram x 50 passes tho
so what are most people setting the parameters for this test to stabilize their system?
is 20passes enough for most systems or is 50?
is all memory good? (i have 4gb in a 32-bit OS) or is 512mb good?
