Linux sound issue
rpc64
I am running RedHat 7.3 which I just recently installed, and I have a Turtle Beach Santa Cruz sound card. Here is what's happening: When I start up X (I'm using KDE) I get an error message saying "Sound server informational message:Error while initializing the sound driver:
device /dev/dsp can't be opened (No such device)The sound server will continue, using the null output device." Obviously, I get no sound. However, when I restart X I get no error message and the sound works. The sound card is detected when RedHat loads and I'm just using whatever default drivers it gave me when I installed. How can I make the sound work the first time I boot up?
So basically it's saying I'm screwed with my Santa Cruz and Linux? But I could have sworn I read somewhere a long time ago that the Santa Cruz was supposed to work with Linux.
did it ever worked before ????
did you run kudzu at boot... ???
this Link
might help...
it contains rpm's for a lot of sound cards
Ok well it seems that the Santa Cruz isn't very compatible with Linux and I'm only going to be able to get 2-channel sound out of it🙁 Oh well. I have a couple other little questions to add. 1. What is the best Linux mp3 player? 2. If I want a program to start when Linux loads, where do I put it? Thanks.
1. Uh best? Most people use mpg321 (often installed as mpg123). If you need an X app, they use XMMS, which is a graphical wrapper for mpg123.
2. I'm not familiar with sysV init (being a slackware user myself), but in /etc/rc.d/ is where startup scripts are located.
