Wrong driver so that's why you get the delay message.
🙂 You'll need to get the 8139 driver. Argh. Well, time to compile it I guess.
Heh, I grabbed the driver from D-Link's site and they have instructions:The procedure to activate DFE-530TX+ on linux is as follows. You can ignore step 1 since you already have the source file, granted it's just called 8139 though. Hmm, do you have that rtl8139.o file in your /lib/modules/<kernel name>/net directory? If so then substitute that module for the one I said was 8139. Ought to work then.
step 1: ftp the driver from
ftp://cesdis.gsfc.nasa.gov/pub/linux/drivers/rtl8139.c
step 2: compile:
The instruction for compiling the driver is include at the end of
the driver file. (run this instruction at /usr/src/linux)
Use this command to compile the driver.
compile-command: gcc -DMODULE -D__KERNEL__ -Wall -Wstrict-prototypes -O6 -c rtl8139.c `[ -f /usr/include/linux/modversions.h ] && echo -DMODVERSIONS`
step 3: insert the driver as module:
insmod rtl8139.o
parameter can be added by adding options=... behind the istrruction
0x16(bit 4):full duplex
bit 0-3
😀efault port
(run 'lsmod' to see if the module is inserted)
step 4: bind your card to an IP address
/sbin/ifconfig eth0 ${IPADDR} broadcast ${BROADCAST}
netmask ${NETMASK}
(run 'netstat -i' to see if there is a interface 'ne0')
step 5: add your card to IP routing table, then add gateway also your card:
/sbin/route add -net ${NETWORK} netmask ${NETMASK} eth0
(should be able to ping local network now)
gateway:
/sbin/route add default gw ${GATEWAY} netmask 0.0.0.0 metric 1
step 6: start inet deamon.
/usr/sbin/inetd
(you are on the network now)
*make sure that your kernel is built with network, fast_ethernet and module
support. Otherwise, you have to rebuild your kernel.
(1:go to /usr/src/linux directory
2:run 'make menuconfig' or 'make config'
3:mark the options list above.
4:exit and rebuild your kernel.
make dep;make clean;make zImage
the file 'zImage' will be at /usr/src/linux/arch/i386/boot/zImage
5:modify /etc/lilo.conf.(this file specify where kernel image is)
6:run 'lilo' )
You cna run 'netconfig' which will do step 4,5,6 for you. This will create
'/etc/rc.d/inet1' and 'inet2' files. These two files will run at boot time.
Then just add a line at the beginning of 'inet1'.
'insmod /your driver'path/rtl8139.o'
then your driver will work every time you boot.
[edit]Ignore the first part of this post cause you have the driver.[/edit]
