Linux Maintenance
well ... i got bb running in here ... that p200mmx ( i just moved from slack 7 to 8 ) ...
good wm, fast ... but there were some issues ...
is there some script-way to run bbkeys without calling bbrun and make everything by hand ?
how can i make it know that the sys is multiuser ... bb just reads 1 conf file at /usr/local/share/blackbox/*, i've made some changes, both by bbconf and bbrb ... but it only reads /usr... i have a $HOME/~.blackbox but it is ignored ...
does anyone knows how to or where to look for info to fix this ?
thanks
matheus
ok ...
but bbrb writes in ~/.blackbox/* ... i saw it writting there ...
well ... is this a version issue ... in the old ones there were no bbconf ... i suppose ... is this right ?
matheus
<< ok ...but bbrb writes in ~/.blackbox/* ... i saw it writting there ...well ... is this a version issue ... in the old ones there were no bbconf ... i suppose ... is this right ?matheus >>
Old ones being what version? I have 0.61.1. It reads ~/.blackboxrc for configuration stuff. I have no clue how bbconf works. I use vi to edit the configuration file which I named for you already. ~/.blackbox/ is a directory where I store all of my styles and my customized menu. I configured bb to look in that directory by changing ~/.blackboxrc to look in that directory for a file called menu. Pretty simple.
