Linux distro webserver only?
drag
8,708
Conanical's support is a bit expensive.
http://www.canonical.com/support
750 dollars per year for basic server support.
If you need support it's not like you can't get it for Debian.
http://www.debian.org/consultants/#US
And HP does professional support for Debian.
http://h20219.www2.hp.com/services/cache/442406-0-0-225-121.html
The way I look at it what Ubuntu needs to do to set itself appart from (currently cheaper) offerings from Suse and Redhat is to work on a tight intergration between it's server and desktop systems. Something like Microsoft SBS, were you have client and server pre-configured to work together in a domain.
Brazen
4,259
Thanks drag, I did not know about those Debian support options, unfortunately we don't have HPs and I don't trust some guy consultanting. I was a little terse with my reasoning though, I suppose. I also liked that Ubuntu had newer packages, but once Etch goes Stable, than that won't be so (only considering the LTS releases for Ubuntu). I have also been thinking (and hoping for) the exact same thing you mention with integration between server and client. Maybe not so much like SBS, but like Active Directory at least, for Linux. I've been hoping for that from the FOSS community for a long time, actually. Something that can push out software and policies to linux member servers.
I see Ubuntu as especially poised to fill that role. Though frankly, I don't think they have the manpower to make such a thing happen on their own. I think they was have to rely on a big showing of volunteer developer support for such a thing which so far has not happened.
you2
7,188
2,226
I run ubuntu but i definitly prefer debian (don't ask why i run one but prefer the other) :)
Btw xhost (for the desktop version of ubuntu) is set to xhost -).
I wont' comment on slackware since i'm happy with the distribution i don't actually run (don't ask).
(yes i use debian on 'other systems' just not my home system which uses ubuntu (which I don't prefer :) )
drag
8,708
You'll probably most likely see a domain desktop/server integration coming out of Fedora. They have their stateless Linux project and they have their Fedora Directory system (open source ldap).
Personally I used Xen + Debian + Kerberos + OpenLDAP + OpenSSL to setup a AD-style SSO domain before, for evaluation. Used SSL encrypted OpenLDAP with Kerberos and it worked pretty well. No patching was needed or anything. Also integrated OpenAFS for file serving.
Since then I've blown it all away. I think this weekend I want to work on taking my notes and figuring out a proper tutorial on how to setup a evaluation system using Vservers (much lower resource usage then Xen. You need VM for proper setup on small amounts of machines as in the real world you will idealy want to use seperate physical servers for each service for security reasons).
I also want to explore integrating CFengine and Samba. I don't know what to do about email or whatnot. Maybe take a look at Webdav and integrating that with SSO/LDAP for maybe a collaberation documentation and versioning service. But these things I will only look at once I get the basic setup going.
All of this should be workable using the default packages aviable to Debian Etch. I would also like to produce a couple working Qemu images (one image full of vserver for the service side and another image for emulating multiple clients) so people can look at working examples.
This sort of thing is pretty workable once you get it going, but the pain (especially with OpenLDAP) is getting a initial configuration running correctly. books and documentation tend to concentrate on what you can do after you get it running, not the basic steps for getting it going in the first place.
Sunner
I think I read about a new consolidated authentication GUI for Ubuntu in one of the future release plans.
I only skimmed through it, but it basically looked like they were gonna make some sort of subsystem to handle whatever sort of auth you'd like(LDAP/AD, Kerberos, etc, the more common ones basically) and a GUI to go with it.
I don't remember if there was any corresponding server software mentioned.
