- Oct 17, 2008
- 33
- 0
- 0
I am having two problems with a Linksys router
1. I flashed the rom on it and now the routers setup page will not display correctly on my Windows 7 computer. I have tried different cables and when a setup page loads, only part of it shows up. If I refresh the page sometimes more will show up. The weird thing is that all the setup pages display perfectly on another computer I have which is running XP. Any ideas? Could it be some security setting in 7?
2. The Wan port is very iffy. Every cable I stick into it seems to not want to make a connection. It is almost like all my RJ-45 plugs are too small and not making a good connection. The lights on the front of the router flash on and off for the WAN port. Again, I have tried a bunch of different cables and they all seem to not connect.
I am using the onboard gigabyte lan port from my ASUS m4a77d motherboard. The router doesn't like the speed of it so I have to set the ethernet connection to 10 Mbps full duplex.
Any ideas or suggestions would be great
