Light anti-tank weapon is only $1500?
35,515
Originally posted by: Ronstang
Originally posted by: Newbian
Originally posted by: Gothgar
bad ass
wonder how much the ammo is and if the local range would let you fire a couple rounds down rage :p
That's the problem.
They get you with the cheap price of the unit but jack the price up of the ammo. :|
These rockets ARE THE AMMO. They are one shot with no ability to reload. They are like everything else made in the world today, self contained one use items that end up in a landfill. In essence they end up being more expensive because you have to buy a new gun each time you fire one.
This makes me angry. :| We ought to provide recycling bins on the battlefield.
*kjm
2,222
bad ass
That's the problem.
They are made that way for a reason. One time use means if one were to ever fall in enemies hads they cant hurt you! That and they are much smaller and lighter to haul around.
35,515
bad ass
That's the problem.
Soldiers are supposed to crush the tube after use to prevent reuse as a mortar tube.
*kjm
2,222
I know I was in for 8 years:) Point is they dont get in the wrong hands.
And they are worth the cost for our men!
edro
24,326
68
Originally posted by: BrunoPuntzJones
That's not really the LAW...which was the M72
Originally posted by: edro
Those basically just through molten shrapnel inside the tank, killing the operators, right?
The explosion on impact just thrusts the core through the tank hull.
Pretty much. Shaped charge blows a hole in the side and shrapnel/spall chews the insides up.
Sooo... not that great against zombies?
lupi
32,539
260
I saw an article about the swedes modifying it with a water volume to minimize the backblast so you could fire them from close quarters. Won't harm you are your buddies around you, but that's got to be one damn terrifying test when it's first done with humans.
Newbian
24,779
882
Originally posted by: AndroidVageta
Originally posted by: judasmachine
I read somewhere that an AK-47 in central Africa goes for a chicken.
I opened a KFC...I now have my own militia.
Well that's because you sold chicken and waffles there.
AndroidVageta
Banned
Mar 22, 2008
2,421
Don't forget cornbread and black-eyed pea's!
Pocatello
9,754
It's relatively cheap, and effective. The Swedes make the AT-4 and the Carl Gustav. Almost all infantry units in the western world carry one these around.
LordMorpheus
6,871
Shaped charges are awesome.
We use them in the oil field. You drill your hole, then you stick a tool down to the layer that has oil / gas and detonate some shaped charges that give us little tunnels out into the formation for the fluid to seep into and then come up to the surface. Some of the bigger charges will punch a 1cm hole 6 feet deep into rock. Like I said, cool stuff.
Before shaped charges they'd just shoot bullets instead, but you couldn't get them to go as deep and they'd crush the rock around the hole and things wouldn't flow as well.
Bignate603
13,897
Even if it costs $1500 one hit will turn a vehicle costing 100 times that to scrap. They're an awesome little weapons system.
911paramedic
9,448
...that might be better than a shotgun for home protection. Of course you better leave the house yourself before firing it...
sdifox
101,162
18,201
Armour Piercing round don't do that well against zombies. You need anti-personnel cluster bombs.
