The fact that we have races proves that evolution has continued in recent (geological) history. I expect it to continue and see no reason to believe otherwise.
Surely the next clearest example is sitting at a desk all day. That WILL force an evolutionary change, but you may not see it in your lifetime.
I think the same could happen for space travel. The breakthrough could be in an area we can't even conceive of. Maybe we'll never be able to travel very fast, but we'll be able to store our minds in a computer system and build ourselves new bodies when we arrive. Who knows?
The theory of faster than light travel is sound. Just creating a device that an expand space behind you and contract space in front of you with gravity is a bit tricky. Once we develop that technology, we should be able to travel just about anywhere.
If we had the technology a trip that far would be about spreading mankind across the stars, and would be a one way venture most likely.
I don't think you quite have the concept of evolution down properly. Change is a natural consequence of having a genetic code that is subject to mutation. Sitting in a chair doesn't create mutations. Some folk may be better suited to sit in chairs than others but unless there is a selective pressure that favors them over those less so, no evolution in the direction of chair sitting facility will take place.
It is not just about finding a way to get round the speed of light. You need a massive energy source that would dwarf even the output of a star. It just does not seem likely that a power source of that magnitude is even possible.
It might very well be that the answer to Fermi's famous paradox is that all the aliens are sitting on their home worlds looking out at all the unreachable stars while their own natural resources dwindle until their civilization eventually falls back into a stone age where it remains until an extinction event comes along to kill them off.
That's a great page, I've been there before. To put it in terms of technology that we don't quite have yet (and no guarantees we'll have it), let's look at fusion for the source of energy. The mass of fuel is based on 100% efficiency, which is physically impossible in the first place (Damn you, Entropy!) We know that fusion >>> fission when it comes to energy density. But, in fusion, what percentage of the mass is actually converted to energy (E=mc²)? The answer is starting: only .61% So, to get to the nearest star, assuming 100% efficiency, you need 38 kg of fuel for every kilogram of payload. The amount of mass of fuel per kilogram of payload becomes absolutely enormous. Keep in mind that the mass of the International Space Station is nearly half a million kilograms - and that keeps only a handful of people alive - people who need to constantly be resupplied with food, etc. Make it large enough to provide food & you're looking at at least triple the size. Until we can bend space, we're not going anywhere beyond our solar system.http://math.ucr.edu/home/baez/physics/Relativity/SR/rocket.html
At a constant 1g you would be surprised how fast we could get moving.
On earth a long time would pass, but for the people traveling near the speed of light much less would be experienced.
From what I've read, it would take about 82 years AT LIGHT SPEED to reach the center of the Milky Way, let alone other galaxies!
Yeah, I think the best we could humanly do is watch and wait for another "WOW" signal.
Even then, there would be little to worry about. The galaxy isn't that dense. It would be like having a dozen blind birds leave Europe toward the US, and a dozen leave the US (from random locations along the coast) headed toward Europe, and worry about the birds colliding with each other somewhere over the Atlantic.Do you have any idea how many stars are in the milky way? There would be no reason to have to leave our galaxy, except for the fact that andromeda will collide with the milky way in the distant future, but thats a problem so very far in the distant future we may as well not even think about it.
You could cross the milky way in 12 years of experienced time at 1g of constant acceleration.
It is not about accelerating to the speed of light. IIRC the amount of energy required to achieve the speed of light increases exponentially and achieving this would require infinite energy. However, with a "warp drive", you don't need to travel faster than the speed of light to go a greater distance than light travels at the same time. This also would remove the time expansion to a degree. If you could reach half the speed of light and compress space half the distance, we could reach it a destination at the same time as light would.
Now, how to achieve this seems to be immense gravity, like that of a star. The sun bends space around it, which is evident because light bends around the sun. That is a particularly tricky device to build.
Gravity. It actually bends space.
As part of my work I've been researching and documenting the evolution of early computers. All of the early digital electronic machines used vacuum tubes, and they were massive. ENIAC weighed 60,000 pounds, took up 1800 square feet and used 150 kW of power. But the machines were improving steadily, so people thought that maybe one day they might be able to get the machines down to, say, 1,000 pounds, so they'd be more practical.
And then came the transistor. And shortly after that, the IC. If you had told the men who designed ENIAC that 50 years later someone would duplicate its capabilities on a device smaller than a fingernail, using 0.00000003% as much energy, and also running 200 times faster, they would have thought you were insane.
Right, I know of no mechanism for gravity to expand space however.
I thought the general consensus today was that dark matter holds negative mass, at least in that it is repelled rather than attracted by gravity, as that is required to explain the universe's expanding acceleration?Gravity is confined by space, well probably. This may be what he's talking about though.
Alcubierre drive
The problem is that this technique isn't dependent on just power but there being negative mass, which has a crapload of theoretical problems to even exist. As far as we know it's unobtaniam in the truest sense of the world.
Why would anyone want to leave this planet anyway?
Not sure if serious...Not sure if serious...
Limiting ourselves to a single planet is just asking for an extinction level event. Like having all our eggs in one basket, which we literally do.
The Earth is fine - humans are the problem.
That being said, I don't think there's a world out there that will not kill us the very second we remove our spacesuits.
I think the goal is to live in contained environments that we would engineer.
Ahhh... like Total Recall (1993)?
Yeah. I mean, if the Atmosphere wasn't the right mixture, or the right density... if the temperature was wrong... the sun for that system thew out too many flares / radiation. If the ozone was missing. So many factors go into making Earth just right for us - you're correct in thinking other planets are by and large uninhabitable. If only because our biology demands the specifications of this one.
So to solve that problem, we bring our environment with us. We hide ourselves within it. Which creates a metric ton of new challenges, of having to both manufacture and maintain it.
Alternatively we might bio engineer changes to ourselves to help us survive those environments.
