andy5174
I have my voltage set in my Bios to 1.225V. Every time my computer loads cpu-z shows voltage to my processor at 1.232. The system is stable right now as i finished memory test and p95. But i don't understand why why the difference in voltage is there.
Second is temperatures. Running P95 my temps were upper 50ties / lower 60 ties with this OC. I'm using the 212+ and already resat the heatsink twice to try to lower these. When people are pushing 3.8-4.0 what temps are they experiencing. I know i can lower them a bit by turning up my case fans, but like to know what people are getting at various clocks.
1. It's the voltage protection feature called "Drooping voltage" which will make your full load voltage lower than idle/BIOS voltage. If there's a Load-Line Calibration(LLC) option in your BIOS, you can DISABLE it to have your voltage the same or very close to the BIOS voltage.
2. The core temperatures are dependent on the CPU heatsink, CPU fan, thermal compound, PC case, ambient temperature and motherboard. Hence, you can only get useful temp info from peoples who has the SAME CPU heatsink, CPU fan, thermal compound, PC case, ambient temperature and motherboard as you which is pretty hard to find.
