LGA1156 Core i7 & i5 Overclocking Guide
Is it worth being a sticky?
  • Yes
  • No
andy5174
148
This guide was written based on Intel Core i5-750 CPU and Gigabyte GA-P55A-UD5 M/B!
This is for peoples who want to OC their PC but lazy to comprehend the basic knowledge of overclocking!
Thus, please don't criticize it for its unprofessional way of writing.
Warning: Overclocking DOES void the warranty. Neither AnandTech nor I will be responsible for any damage caused by overclocking!
0) HSF & Thermal grease
1) Decision making on the OC
2) How to start?
3) Voltages tweaking
4) Torture test
(This is just my cooling solution but not recommendation! Click here to visit Cases & Cooling board for cooling advice.)
- Prolimatech Megashadow heatsink paired with 2x 2000rpm 19dB CoolerMaster SickelFlow Fan
- Arctic Silver 5 thermal compound
(Check here for the guide on thermal compound application)
What is the best OC?
Performance-efficiency wise
- The maximum OC that can be achieved near stock core voltage(1.20V shown on CPU-Z at 100% load).
- Power consumption increase is in LINEAR region! (The power increase in an exponential form after 3.6GHz -> Bad efficiency!)
(For LGA1156 CPUs, 3.6GHz OC satisfies these two conditions.)
Performance ONLY
The maximum frequency that can be achieved within the absolute maximum core voltage(1.55V for LGA1156 CPUs).
To be safe, you want to be within the maximum core voltage which is 1.40V for LGA1156 CPUs.
[FONT=&quot]LGA1156 CPU Documentation from Intel![/FONT]
2) How to start?
1. Enter the BIOS by pressing Delete key during POST(Power On Self Test)/Boot Screen.
2. Set BCLK, CPU multiplier/ratio, QPI Clock multiplier/ratio and Memory multiplier/ratio so that you can achieve the frequencies you want.
BCLK x CPU ratio = CPU frequency
BCLK x QPI ratio = QPI link speed -> set the ratio to the lowest possible value!
BCLK x Memory ratio = Memory frequency
My settings are:
CPU frequency: 180x20=3.6GHz
QPI link speed: 180x32=5.76GHz
Memory frequency:180x8=1440MHz
3. Manually set the memory timing according to the specification of your RAM, leaving everything unspecified as Auto.
(You have to set the DRAM Timing Selectable to Quick or Expert in order to do this in P55A-UD5!)
4. Disable the Turbo Boost Technology!
5. If it's impossible to get your system stable, disable C1E, C3/C6/C7 and EIST.
(p.s. C1E, C3/C6/C7 and EIST are power saving features and CPU will always run at highest clock when ALL of them are disabled.)
For i7-8xx CPUs, disable HT (Hyper Threading Technology) as well under this situation.
Immensely useful information from Intel Datasheet! Give it a read before you move on, because it is going to help substantially in the following steps!
PCH: Intel P55 chipset voltage
- main I/O interface
- display connectivity
- audio feature
- power management
- manageability
- security
- Storage feature
It is pretty obvious that the higher the CPU frequency, the more frequent the I/O(input and output) and so the higher the power consumption of "main I/O interface". Hence, the PCH voltage needs to be increased based on the same current(P=VI). However, 1.10V should be sufficient for any OC achieved on air cooling.
PLL: Phase Locked Loop voltage
- Processor/IMC(Integrated Memory Controller)/other internal clocks
- Clock multiplying of processor is provided by an internal Phase Locked Loop
Generally, 1.8V(default value) and 1.9V for OC under 3.6GHz and 4.2GHz respectively.
Vtt
- L3 shared cache
- memory controller
- processor I/O power rail
Since memory controller frequency is dependent on BCLK, the higher the BCLK, the higher the Vtt required.
1. To achieve the absolute maximum OC, begin with applying the Maximum voltages(to be safe) or Absolute Maximum voltages(at your own risk) in BIOS.
(LGA1156 CPU Maximum/absolute Maximum voltage by Intel: Vcore= 1.40/1.55, Vtt= 1.155/1.21, Vram= 1.575/1.65, PLL= 1.89/1.98) with PCH=1.10
For i5-750 ONLY: The following settings are good points to start with!
In order to find out the minimum stable voltages, keep lowering the following voltages ONE at a time until your system becomes unstable.
(For example, varying ONLY the Vcore with all other voltages FIXED while trying to find out the minimum stable Vcore.)
The lower the voltages are, the cooler and healthier the CPU is!
3.6GHz:(24hrs Small FFTs test, 30hrs-2mins Large FFTs test and 14hrs-12mins Memtest86+ stable!)
Load-Line Calibration: Enabled (or Level2 for Gigabyte GA-P55A-UD5)
Vcore= 1.21875V
QPI/Vtt/IMC= 1.14V
PCH= 1.10V
PLL= 1.80V
RAM= Specified voltage for your RAM
3.8GHz:
Load-Line Calibration: Disabled
Vcore= 1.32V
QPI/Vtt/IMC= 1.16V
PCH= 1.10V
PLL= 1.88V
4.0GHz:
Vcore= 1.45V <- Higher than maximum Vcore
QPI/Vtt/IMC= 1.25V <- Higher than absolute maximum Vtt
PCH= 1.10V
PLL= 1.88V
4.2GHz:(Provided by The Sauce)
Vcore= 1.350V
QPI/Vtt/IMC= 1.20V <- Higher than maximum Vtt
PCH= 1.10V
PLL= 1.90V
2. Set BCLK=210 with CPU Multiplier=20, (210,20), OR BCLK=200 with CPU Multiplier=21, (200,21), to make the CPU 4.2GHz which is the maximum on average chips.
3. Check for stability of your system:
- Stable: Jump to the next step, 4) Torture test, for thorough stability test. OR Set the BCLK and CPU Multiplier to (215,20 ) or (205,21) to get higher frequency.
- Unstable: Up the voltages at your own risk. OR Lower the BCLK and CPU Multiplier to (200,20) or (190,21) to be on the safe side. Keep repeating this until your PC is stable.
4) Torture test
1. Software required: CPU-Z, HWMonitor, Core Temp, Memtest86+ and Prime95
2. Run at least 12 hours Memtest86+ test and Large FFTs test of Prime95.
Monitor 100% load core temperatures
During the test, make sure that your core temperatures are ALL within 72.7C which is the thermal specification from Intel!
p.s. Under 18C ambient temperature, my 100% load core temperatures are 48C-44C-44C-43C at 3.6GHz with the cooling solution specified earlier.
Prime95 Torture Test Options
- Small FFTs: CPU Stability test
- In-Place Large FFTs: Overall system(CPU/RAM Interface) stability test
- Blend: Mainly memory stability test, NOT very useful! Use Memtest86+ instead
Click here for Prime95 Instruction!
Go back to 3) Voltages tweaking and up the voltage a notch if it's not stable!
*Tip*: The best way to find out which voltage is causing the instability is setting the voltage that might be too low according to your 6th sense to its maximum value with ALL other voltages staying unchanged and see if the system is stable after this. If the system is stable, then it's the voltage you need to tweak. If the system is still unstable, try tweaking another voltage in the same way.
For i5-750 ONLY: You might be extremely unlucky to have a chip that is much worse than the average with the stable voltages being much higher than those values given by me. What I would do under this situation is setting all the voltages to their maximum(NOT absolute maximum) values and lowering them ONE at a time until you get instability. However, try it again with C1E, C3/C6/C7 and EIST disabled before doing so.
(p.s. Maximum/absolute Maximum voltage by Intel: Vcore= 1.40/1.55, Vtt= 1.155/1.21, Vram= 1.575/1.65, PLL= 1.89/1.98)
N.B. Any OC below 3.8GHz should be very easy and don't go above that if either of your core temperatures or core voltage is already near its maximum specification at the point.
Good luck!
Markfw
May 16, 2002
27,404
16,255
OK, whay don't you change the title a little (add guide) and add a poll as to whether is is encompassing enough to have a sticky. And if people add suggestions, edit the main post to indicate that.
andy5174
148
How to do that? I couldn't find any "poll" option there.
Markfw
May 16, 2002
27,404
16,255
Andy (I assume thats your name) Since this website is virtually owned by the users, thats why I had you add a sticky. If they want it, and this is a good one, I will sticky it.
Good luck.
Gillbot
28,830
17
andy5174 said:
0) A good HSF & Thermal grease
IMHO, i'd leave the product suggestions out of the mix, but that's just me. It's bound to create an unneeded debate in a thread.
Voo
1,684
I'm not that comfortable with advising everyone to disable EIST and Co per se - personally I'm fine with a little lower OC, but EIST, though that's just me (and at least for 3.6/3.8ghz I can't imagine it to be necessary)
Other than that, good guide (although I wouldn't like 1.52V Vcore on air - but you outlined it as being rather high, so it's their own responsibility) and your English is fine ;)
imported_RJR
22
Everything looks pretty good, but, I would recommend you mention to monitor temps in an earlier part of your guide. If the person is new to OCing and follows your guide without reading the entire guide first, he/she could get into a little trouble with temps. You have them adjusting voltages and doing torture tests before mentioning the fact that monitoring temps is very important and must be done through the entire process. I would definitely mention this as soon as any voltage change is considered, especially max voltages.
Overall, not a bad beginners guide.
Oh, almost forgot, Prime95 blend is not only for testing ram, but you are correct that Memtest would be the way to go if you are only testing ram. Blend has been a staple for many people for quite some time now as it stresses both cpu and ram.
@Gillbot, I would have to agree, people can make up their own minds about what cooler and Tim they use, I don't think suggestions should be made even though I use a Mega Shadow myself.
andy5174
148
Gillbot:
I will remove them if this happen.
Voo:
"Turn off C1E, C3/C6/C7 and EIST if it's impossible to get your system stable" was what I originally put in that place. I will change it back then......
imported_RJR:
OK. I will change it now.
Adrenaline
5,320
8
It is nice to see a thread on OC an 1156 but I would get suggestions for the other models of chips as well to put in a setup like you did for the i5-750. put them into a nice format like yours and give credit to whomever gave the numbers.
I have the suggested heatsink. I had to cut part of my fan bracket wall in my CM Stacker 830 to get it to fit. I am going to clip it more when I put my new HDDs in.
For HSF suggetions, you could just post a link to the thread on these forums. I blieve RussianSensation made the list or he commeneted in the post with some good suggestions.
andy5174
148
No voltage settings were given for i7-8xx as I don't have one myself.
In addition, the numbers given by others are hardly reliable most of the time, considering a lot of peoples determining the stability by running the torture test for merely 1 hour or even less AFAIK.
However, I will be more than happy to add numbers given by peoples who did In-place Large FFTs test of Prime95 for at least 12 hours.
p.s. I don't trust Small FFTs test, because I had experience in failing Large FFTs in just 4 hours SEVERAL TIMES given it was 24 hours stable in Small FFTs test.
andy5174
148
Some very useful information added in 3) Voltages tweaking after a more thorough reading of Intel datasheet.
Gillbot
28,830
17
Agree 100&#37; here
Remove them before it happens. Otherwise the thread will get derailed and locked. Depending on the mess, it may not get cleaned up and will ruin an otherwise informative thread.
How about now? (IN MY OWN OPINION. NO DEBATING, please!) added. ;)
IMHO, not sufficient. Leave any product suggestions out completely.
Markfw
May 16, 2002
27,404
16,255
On the HSF, just say "an example of a decent mid-range... and example of a good high end... HSF". That leaves the recomendation out, but then you can leave the pictures in.
andy5174
148
I had left out all "the best" in the descriptions so that peoples won't argue what are the best or which is better.
Hope that make you feel better.
If you are still uncomfortable with them... OK, let me know and I will remove them.
andy5174
148
That is exactly what I had just done.
Thank you for the advice!
Gillbot
28,830
17
Personally, i'd leave it all out and let the user do their own research.
CoolerMaster Hyper 212 Plus has great performance for the cost.
- Prolimatech Megashadow is one of the top heatsinks which is used with 2x 2000rpm 19dB CoolerMaster SickelFlow Fan here.
The above bolded items seem like a sales pitch to me and could cause debate.
If you are insistent on leaving them in, i'd reword it to be something along the lines of:
CoolerMaster Hyper 212 Plus or Prolimatech Megashadow are two examples of good heatsinks.
Inevitably, someone will buy one of the two you recommend and NOT hit a high OC, then the thread will be filled with debate and turn into a mess. We've all seen it a thousand times.
Personally, I'd leave it all up to the user to the effect of:
2) How to start?
4) Torture test
Research here and here to determine what coolers and thermal compounds will suit your needs and budget. Keep in mind that the better cooling you get, the better overclock you may be able to achieve.
Gillbot
28,830
17
You still don't get it.....
CoolerMaster Hyper 212 Plus (decent mid-range HSF)
Prolimatech Megashadow heatsink (high end HSF) which is paired with 2x 2000rpm 19dB CoolerMaster SickelFlow Fan here.
These are your OPINIONS, not fact. This is why I suggest leaving them OUT completely.
