LG VX4400 - Battery Replacement
LuckyTaxi
Is it safe to assume my cellphone battery is done? I would charge it overnight and then it would go dead by the next evening. Mind you, I usually dont use it during the day since I am at work.
I found batteries on ebay, and they're listed as cheap as $10. I'm not sure if they're the same quality, but for $10, that's not a bad deal. I would get the extended, but I would need a new holster. Anyone with experience buying cellphone batteries off of ebay? Do they really work well?
