I have an almost 10 yr old LG LCD monitor L177WSB
Of late I have noticed that when I turn on my system, the power button LED starts blinking fadely with a blue color. Under normal conditions, the LED stays a steady Yellow on Standby and Steady Blue on being powered on.
I have to press the power button quite a few times before any display comes up and every time there is some sort of display on the monitor, like the Mobo Model No, Windows Boot Screen and when the monitor is finally on, I hear a mild hissing sound coming from the back of my monitor. The power button LED finally goes to a steady blue when the monitor is up and running.
Sometimes, when I try to turn on the monitor, I get White and Green Flashes on the screen and my PC freezes (I am unable to reset it), the only way is to switch it off from the mains and turn it back on.
I checked the Event Logs, and found these errors logged
The following boot-start or system-start driver(s) failed to load: atc
Event filter with query "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected.
So before I invest in a new monitor, I wanted to know if this event log indicates a problem with the monitor itself or with its drivers
